Latest post 03-27-2010 1:20 PM by joeyboygolf. 5 replies.
Page 1 of 1 (6 items)
  • 03-25-2010 7:38 PM
    • a11mcr
    • Top 500 Contributor
    • Joined on 07-29-2007
    • Redcar,North East
    • Posts 154
    • Silver Member
    RIAA can one be made?
    hi i was wondering if the RIAA that is built into the modern beograms (i.e BG4500/9500 etc) can be home made and fitted into an older deck (BG3000/3300) if so does anyone have a diagram and part's list?
    many thanks
    mark
    Kind Regards, Mark
  • 03-26-2010 6:11 AM In reply to
    • Churchyardd
    • Not Ranked
    • Joined on 03-25-2010
    • Deventer, Netherlands
    • Posts 31
    Re: RIAA can one be made?
    Hi Mark,
    I have to say that I am not very familiar with all B&O record decks, but I do know something about RIAA circuits. As long as there is a DC power supply (like +/- 15V), or room for a power supply inside the turntable, you can build in any RIAA circuitry you like. There are many circuit diagrams available on the internet and they can quite easy be made home as long as you have any experience in electronics.
    Regards,
    Bart.
  • 03-26-2010 6:58 AM In reply to
    You can make one - I think one of our members has done so. However a small external one will probably be much easier - you can get datalink to work using a separate wire.
  • 03-27-2010 12:24 PM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    thanks.
    does anyone have a diagram for the ones that are built in to newer decks i.e bg4500/9500.
    i have had a look on the net but cant seem to find any (must be me looking in the wrong place?)
    mark
    Kind Regards, Mark
  • 03-27-2010 1:19 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    maplins sell one in kit form by wellmann - i've had good results in a sony turntable separate mounting the board in the box  and using the motoe dc supply with a smoothing/hum redduction circuit
    when are you to send pics of the beocord 3500 deck?
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 03-27-2010 1:20 PM In reply to
    It's in the service manual!
    Regards Graham
