Latest post 03-26-2010 9:44 PM by matbkk. 5 replies.
Page 1 of 1 (6 items)
  • 03-25-2010 6:54 AM
    STB MENU
    My BV7 is quite old ;  I have only DVI input. When I connect a TVIX 6500 and set correctly the STB I cannot get the menu shortcut on screen ! It shows a grey "DVI menu" and i can adjust brillance....
    I tryed to connect the TVIX on V-MEM via scart, and it's ok it shows the menu shorcut.
    Anyone has the same problem ?
    Mat
  • 03-26-2010 6:20 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: STB MENU
    What happens if you press MENU twice?
    Stefan
  • 03-26-2010 9:16 AM In reply to
    Re: STB MENU
    Nothing. The "DVI setup" stays on screen.
  • 03-26-2010 11:39 AM In reply to
    Re: STB MENU
    Mine does the same, and the manual confirms this is correct.  It only happens if the STB is connected to DVI socket
  • 03-26-2010 2:09 PM In reply to
    Re: STB MENU
    matbkk:
    Is it a problem?
    Just use "Go" followed by the number or colour gives the same result.
  • 03-26-2010 9:44 PM In reply to
    Re: STB MENU
    Hi Beobuddy,
    Actually you are right I was trying combination "MENU" followed by the number or colour. But we can get the same result with "GO" so now it's fine
    Thanks.
    Only thing is if you forgot the combination you cannot check the shortcuts by pressing menu.
    Mat
