My BV7 is quite old ; I have only DVI input. When I connect a TVIX 6500 and set correctly the STB I cannot get the menu shortcut on screen ! It shows a grey "DVI menu" and i can adjust brillance....
I tryed to connect the TVIX on V-MEM via scart, and it's ok it shows the menu shorcut.
Anyone has the same problem ?
Mat
