You can watch two pictures side by side in P and P mode. This will work with any video source on your BV7-40. TV, DTV, V.MEM, DVD, PC, DVD2, V.AUX... For video sources that are not directly available on your Beo4 - V.AUX, PC, DVD2...- you must add a button to the list, for example P-V.AUX, P-DVD2... You will have sound from the left picture and remote control to the right picture. To swap the two pictures (and the functions) just press "0". To exit P and P mode, select the video source you want to watch. P and P mode also works with HD sources. I think it`s a great feature. I can set a record timer to my external HD stb without interrupting the current program of the internal stb.
Stefan
