I feel embarressed
Had some dust behind the glass part of my Beolink 7000.
I managed to remove the glass in order to clean the blue matrix display.
That worked! Now it's time to replace the batterie. That didn't work! Why? I connected the batterie the wrong way (+ and -).
I noticed that when the Beolink was going on and off while it has been charging for around 5 minutes on the table charger!
My first thought immediately was that I must have the batterie connected the wrong way. Made it open and my thoughts were right!
Sh......t!!!! Funny smell also, the well known smell of a burned electronic component. Results now? Beolink is still working on the charger and everything seems to work but it keeps randomly switching to more or less options going on and off on the display. I still have acces to all the menu's. It doesn't work on the batterie anymore.
Is there any chance the Beolink can be repaired (Dillen, Ulf Kiener, Menahem, Die Bogener or other electronic specialists on this board?).
Any advise from you guys would be much appreciated!
Really feel stupid
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
