Latest post 03-08-2010 10:26 AM by Dillen. 8 replies.
Page 1 of 1 (9 items)
  • 03-05-2010 1:39 PM
    S-45 Woofer Replacement
    Hi Guys,
    I just got a pair of S-45's the ones with the two part grills, with a lovely BeoCenter 7700. Both in excellent cosmetic conditions for their age. My question is what replacement woofers should I put in as a replacement to the destroyed ones? I know SEAS made them, but I really haven't found one I am truly 100% on.
    Also, any recommendations on what to use to change the speakers from wood color to a Piano black finish?
    BV7-40 MKIV, BeoVision Avant 32, BeoVision 8-32, BeoLab Penta MKIII, BeoLab 6000 x 3, BeoSound 9000 MKIII, BeoLab 7-4, BeoSound 4000, BeoPort, BeoVox S45-2, ML/MCL Convertors, A8's & Form 2's.
  • 03-05-2010 3:27 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: S-45 Woofer Replacement
    Dont' replace the woofers. Have them refoam'ed instead.
    It's the best and cheapest solution.
  • 03-05-2010 3:49 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    BeoMegaMan:
    Why?
    The veneer used by B&O on these speakers is just gorgeous.
    Martin's right re:- the refoaming.
    Chris.
  • 03-05-2010 4:15 PM In reply to
    It's damaged past the foam. The cone is punctured on both of them. As far as the veneer goes, it's just not my taste. I want to either de-grill them and have them all black or paint the cabinet white and still keep the fronts black.
  • 03-05-2010 4:22 PM In reply to
    • Dillen
    • Posts 5,008
    The Beovox S45 (type 6427) woofer is a 6.4 Ohm impedance driver which means that it
    will be practically impossible to cross to a modern driver.
    I may have a pair of good used original woofers already refoam'ed, I will check.
    Re finish, these speakers were actually produced in white though a bit rare to see.
  • 03-05-2010 4:51 PM In reply to
    Hi Martin,
    I would be interested in them if you have them for a good price. The finish in white is where I got the idea from.
  • 03-06-2010 12:12 PM In reply to
    • Medogsfat
    • Posts 4,045
    THIS may be of some help with the cabinets. To get a high gloss finish is quite intensive & there are no real short cuts (according to my brother who is a master cabinet maker).
    Chris.
  • 03-06-2010 2:04 PM In reply to
    Thats funny as i was just on that site also!!!
  • 03-08-2010 10:26 AM In reply to
    • Dillen
    • Posts 5,008
    Yes, I have two original woofers, refoam'ed etc. and ready to mount.
    You have a PM, check your inbox.
