1st March February 2012
Latest post 03-08-2010 10:26 AM by Dillen. 8 replies.
03-05-2010 1:39 PM
BeoMegaMan
- Joined on 11-25-2007
- Posts 66
Hi Guys,
I just got a pair of S-45's the ones with the two part grills, with a lovely BeoCenter 7700. Both in excellent cosmetic conditions for their age. My question is what replacement woofers should I put in as a replacement to the destroyed ones? I know SEAS made them, but I really haven't found one I am truly 100% on.
Also, any recommendations on what to use to change the speakers from wood color to a Piano black finish?
BV7-40 MKIV, BeoVision Avant 32, BeoVision 8-32, BeoLab Penta MKIII, BeoLab 6000 x 3, BeoSound 9000 MKIII, BeoLab 7-4, BeoSound 4000, BeoPort, BeoVox S45-2, ML/MCL Convertors, A8's & Form 2's.
Dillen
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
Re: S-45 Woofer Replacement
Dont' replace the woofers. Have them refoam'ed instead. It's the best and cheapest solution.
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
BeoMegaMan:
Why?
The veneer used by B&O on these speakers is just gorgeous.
Martin's right re:- the refoaming.
Chris.
BeoMegaMan
- Posts 66
It's damaged past the foam. The cone is punctured on both of them. As far as the veneer goes, it's just not my taste. I want to either de-grill them and have them all black or paint the cabinet white and still keep the fronts black.
Dillen
- Posts 5,008
The Beovox S45 (type 6427) woofer is a 6.4 Ohm impedance driver which means that it will be practically impossible to cross to a modern driver. I may have a pair of good used original woofers already refoam'ed, I will check.
Re finish, these speakers were actually produced in white though a bit rare to see.
BeoMegaMan
- Posts 66
Hi Martin,
I would be interested in them if you have them for a good price. The finish in white is where I got the idea from.
Medogsfat
- Posts 4,045
THIS may be of some help with the cabinets. To get a high gloss finish is quite intensive & there are no real short cuts (according to my brother who is a master cabinet maker).
Chris.
BeoMegaMan
- Posts 66
Thats funny as i was just on that site also!!!
Dillen
- Posts 5,008
Yes, I have two original woofers, refoam'ed etc. and ready to mount. You have a PM, check your inbox.
Page 1 of 1 (9 items)
