Great news, thanks guys. And i would love to hear those stories : )
Anyway. Here is the info for the BC9500. I have no idea what to look for.
Beocenter 9500 Specifications
Types:
EU 2506 (1989 - Feb 1994)
GB 2507 (1989 - Dec 1993)
AUS 2510 (1989 - Dec 1993)
J 2509 (1989 - Dec 1993)
US 2508 (1989 - Dec 1993)
Amplifier:
Long-term max. output power: IEC 2 x 80 watts / 8 ohms
Total harmonic distortion IHF: < 0.1 % & 30 watts 20 - 20,000 Hz
Dynamic headroom 1 dB: / 8 ohms
Intermodulation IHF: < 0.1 %
Bass control at 40 Hz: +/- 10 dB
Treble control at 12,500 Hz: +/- 8 dB
Tape recorder:
Compact cassette C46 - C120
Recording system HX PRO
Tape head Sendust
Wow and flutter DIN < 0.15 %
Frequency range chrome 30 - 18,000 Hz +/- 3 dB
Signal-to-noise ratio CCIR/ARM
Metal Dolby NR B:>64 dB, C: >73 dB
Chrome Dolby NR B:>65 dB, C: >74 dB
Ferro Dolby NR B:>63 dB, C: >72 dB
Power supply: 110 - 130 - 220 - 240 voltage switch
Power consumption Max. 200 W
Dimensions W x H x D 76 x 11 x 34cm
Weight 14 kg
Tuner:
FM range: 76 - 90 MHz (Type 2509, 2513)
87.5 - 108 MHz (Type 2506, 2508, 2510, 2511, 2512, 2514)
LW range 2506, 2511: 150 - 350 kHz
MW range 2506, 2508, 2509, 2510, 2511, 2512, 2513, 2514520 - 610 kHz
Compact disc player:
Frequency range 3 - 20,000 Hz +/- 0.3 dB
Signal-to-noise ratio > 100 dB / 110 dB A-weighted
Dynamic range > 96 dB
Harmonic distortion 0.0025 % at 0 dB
0.0025 % at -20 dB
Channel separation > 101 dB
Converter system 2 x 16 bit, 4 x oversampling
Low pass filter analogue Bessel
Connections: Beocord Tape 1 Built-in
Beocord Tape 2 7-pin DIN, Datalink
Beogram CD Built-in
Beogram LP 7-pin DIN, Datalink
BeoLab 2 x Power Link
Beovox 4-pin DIN
Beovision 7-pin DIN, Datalink
Link compatibility: Master Control Link
