Latest post 03-17-2008 4:11 PM by gorissek. 25 replies.
Page 1 of 2 (26 items) 1 2 Next >
  • 04-16-2007 1:48 PM
    BeoCenter 9500 with custom speakers - powerful enough?
    Hello everyone.
    I'm getting a BeoCenter 9500 in a few days ( hopefully ) and i noticed it has an ampiflier so i can connect non-B&O speakers. I would like to connect my 15 year old custom made speakers that sound amazing. The problem is, that i have no idea how powerful they are, and if the BeoCenter 9500 will be able to handle them. As far as i've read it has 2x80W. But i'm afraid that won't be enough.
    They are about a meter or so high and about 50-60cm wide. Sadly, that's everything i know, since they have no info on them. They are currently connected to a Sony TA-F555ESII ampiflier ( link: http://www.thevintageknob.org/SONY/sonyes/TAF555ES/TAF555ES555ESII.html ) and they work great. Since i'm no techno wizz, i hope someone could help me with this. I know it may be hard, since i have no technical details on speakers, but still. I'm more than happy to provide any additional info, if i can. Thanks in advance.
    PS. the hyperlink button doesn't seem to work on Safari - it's just gray and unclickable. Is it possible i'm doing something wrong? also when you click preview, the text disappears and the smilies don't work :)
    Filed under:
  • 04-16-2007 1:53 PM In reply to
    Re: BeoCenter 9500 with custom speakers - powerful enough?
    here is specs for yout current ampflier. compare it to bc9500.
     RMS Power: 2x 100W (8Ohm) - 2x 100W (4Ohm) THD/IM: 0,004% (20Hz...20kHz, 8Ohm, rated output) 0,001% (20Hz...20kHz, 4Ohm, rated output)
    Bandwidth: 5Hz...100kHz (50W, 8Ohm, 0,02% THD) 5Hz...80kHz (50W, 4Ohm, 0,02% THD)
    Slew rate: 100 Volts/µsec. 250 Volts/µsec (IHF)
    Damping factor: 125 (1kHz/8Ohm)
    Residual noise: 28µV (A-weighted, 8Ohm)
    Dynamic headroom: 1,8dB (4 or 8Ohm, IHF-1978)
    Dynamic range: 120dB
    Frequency response: 2Hz...200kHz (-0,3dB)
    RIAA curve: ± 0,2dB
    Channel separation: 90dB 85dB (phono MM) 90dB (phono MC) MM
    Phono input: 2,5mV/50kOhm MM settings: 100pF or 330pF MC
    Phono input: 130µV/100Ohm at 40Ohm setting 130µV/30Ohm at 3Ohm setting
    Inputs: Tuner, tape, aux, CD (150mV/50kOhm)
    A/V inputs: - S/N ratio: 102dB (IHF-A), 97dB (New IHF) MM
    Phono S/N ratio: 83dB (@2,5mV, IHF-A), 87dB (New IHF) MC Phono S/N ratio: 73dB (@0,125mV, IHF-A), 70dB (New IHF) Maximum input capability: 150mV (MM) 8,5mV (MC)
    Spontaneous Twin Drive
    6 inputs
    speakers A & B
    phono inputs
    Bass boost
    15Hz subsonic filter
    speaker impedance switch 4-6 ohms or 8-16 ohms {will drive just about any system}
    large power transformer for lots of kick in reserve.
  • 04-16-2007 1:54 PM In reply to
    Looking at your old amp and the specifications, you should be ok.
    You do have to bear in mind that a Japanese power amp tends to be seriously optimistic and you might even find that your Beocentre 9500 is at least as powerful as your old Sony.
     I could tell you a few stories about just how optimistic the Japanese power ratings can be.
  • 04-16-2007 1:55 PM In reply to
    i was about the say same thing about optimistic powers.... heh.
  • 04-16-2007 2:05 PM In reply to
    Great news, thanks guys. And i would love to hear those stories : )
    Anyway. Here is the info for the BC9500. I have no idea what to look for.
    Beocenter 9500 Specifications
    Types:
    EU 2506 (1989 - Feb 1994)
    GB 2507 (1989 - Dec 1993)
    AUS 2510 (1989 - Dec 1993)
    J 2509 (1989 - Dec 1993)
    US 2508 (1989 - Dec 1993)
    Amplifier:
    Long-term max. output power: IEC 2 x 80 watts / 8 ohms
    Total harmonic distortion IHF: < 0.1 % & 30 watts 20 - 20,000 Hz
    Dynamic headroom 1 dB: / 8 ohms
    Intermodulation IHF: < 0.1 %
    Bass control at 40 Hz: +/- 10 dB
    Treble control at 12,500 Hz: +/- 8 dB
    Tape recorder:
    Compact cassette C46 - C120
    Recording system HX PRO
    Tape head Sendust
    Wow and flutter DIN < 0.15 %
    Frequency range chrome 30 - 18,000 Hz +/- 3 dB
    Signal-to-noise ratio CCIR/ARM
    Metal Dolby NR B:>64 dB, C: >73 dB
    Chrome Dolby NR B:>65 dB, C: >74 dB
    Ferro Dolby NR B:>63 dB, C: >72 dB
    Power supply: 110 - 130 - 220 - 240 voltage switch
    Power consumption Max. 200 W
    Dimensions W x H x D 76 x 11 x 34cm
    Weight 14 kg
    Tuner:
    FM range: 76 - 90 MHz (Type 2509, 2513)
    87.5 - 108 MHz (Type 2506, 2508, 2510, 2511, 2512, 2514)
    LW range 2506, 2511: 150 - 350 kHz
    MW range 2506, 2508, 2509, 2510, 2511, 2512, 2513, 2514520 - 610 kHz
    Compact disc player:
    Frequency range 3 - 20,000 Hz +/- 0.3 dB
    Signal-to-noise ratio > 100 dB / 110 dB A-weighted
    Dynamic range > 96 dB
    Harmonic distortion 0.0025 % at 0 dB
    0.0025 % at -20 dB
    Channel separation > 101 dB
    Converter system 2 x 16 bit, 4 x oversampling
    Low pass filter analogue Bessel
    Connections: Beocord Tape 1 Built-in
    Beocord Tape 2 7-pin DIN, Datalink
    Beogram CD Built-in
    Beogram LP 7-pin DIN, Datalink
    BeoLab 2 x Power Link
    Beovox 4-pin DIN
    Beovision 7-pin DIN, Datalink
    Link compatibility: Master Control Link
  • 04-16-2007 2:09 PM In reply to
    • ChrDH
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Denmark
    • Posts 493
    At the moment I use my B&W P5 floorstanding speakers together with my Beocenter 9000 (which should be less powerfull than the BC9500) and it works just great. Plenty of control of the speaker, and at a party last weekend it could easily play very loud...
    In time, I will connect the BC9000 with a pair of RL6000 (when i get them wall mounted). By the way, have anyone seen Dillen (Martin)? I have a question about the capacitators of the cross-over of the RLs.
    best regards
     Chr.
    Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
  • 04-16-2007 2:10 PM In reply to
    you should just try it out. i'm sure you won't be disappointed for bc9500 anyway...
  • 04-16-2007 2:36 PM In reply to
    Will do and i'll tell you how it goes. And i am sure it will be spectacular, playing or just sitting there : )
    If it doesn't work by some strange coincidence, is there a way to connect the 9500 to my Sony amp? Or what are the other options?
  • 04-16-2007 2:49 PM In reply to
    I would rate the 9500 as about 40W RMS a channel. Good if not spectacular amplifier. If you need more, use a Powerlink socket and a power amplifier - the Quad 405 is recommended by Graham and will not break the bank. Or get a pair of Beolab 200 amplifiers which will do much the same but will break the bank!Laughing
    By the way, to insert a link, write something like Beocentral , highlight it and then press the link button and put in the URL.
  • 04-16-2007 2:56 PM In reply to
    • ChrDH
    • Denmark
    • Posts 493
    I am pretty shure that the beocenter 9500 has RCA line-out for that same purpose. I know my BC9000 does. Just connect it with a pair of RCA cables to line in (aux) of your Sony amp.
    I suppose you could get a powerlink to RCA converter, if you prefer to use the Powerlink. As Beotech.co.uk i can't check with the spare parts list.
     best regards
    Chr.
  • 04-16-2007 3:09 PM In reply to
    I don't think the 9500 has RCA sockets unfortunately - mine doesn't anyway. There is a pre-amp out which is a DIN socket but using this disconnects the power amp all together which could be a disadvantage.
  • 04-16-2007 3:29 PM In reply to
    Peter is quite correct. The only model with RCA pre amp out sockets is the BC9000. With the 9500 you will have to use the powerlink socket and make up a special lead.
    The din socket that Peter says that the 9500 has was designed for a graphic equaliser (in/out) and is not volume controlled.
    You will have to make up a lead for the powerlink socket I'm afraid.
    Regards Graham
  • 04-16-2007 4:13 PM In reply to
    • PL212
    • Top 200 Contributor
    • Joined on 02-14-2007
    • Moderator - Seattle
    • Posts 318
    Graham, am I mis-remembering or was it so that the 9500 merely attenuated the amplifier signal down for the "pre-amp" out -- in contrast to the earlier 9000 which actually gave you the original signal?
  • 04-16-2007 4:23 PM In reply to
    I think that is the 5500 - just had a look at the diagrams for the 9500 - I confess to being useless at doing this - and the line in and out is before the power amplifiers and so is not attenuated output. It seems to be, as has been stated, before the tone controls as well.
  • 04-16-2007 4:43 PM In reply to
    Correct Peter. Makes sense as well. The din socket takes it's  signal before the volume and tone controls, out to a graphic equaliser and back in so you can then control the volume from the front panel of the 9500.
    Regards Graham
  • 08-24-2007 9:44 PM In reply to
    Hey Gorissek...Whatever did you determine about the ability of the 9500 to drive your speakers???   I picked up a 9500 and am re-furbing it now, i'd love to hear your comparison to your Sony amp...
    THanks,
  • 08-25-2007 2:30 PM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    I had a look at the driver configuration Gorissek is using and it's one I've had experience with. The bass should stay fairly well controlled, I was driving the same cones with a 35 wpch Rotel amp and it sounded beautiful up until medium-high volumes, at which point the mids really began to yelp and screech.
    Of course, this isn't taking into account the differences between the damping factor from the cabinet design on the actual driver and the resistance caused by venting or sealed enclosures, but it's a pretty basic guide. The amplifier in the 9500 actually seems rather good, although if you really want a bigger pair of speakers to sing well, you need something more meaty like a BeoMaster 6500/7000 or 6000/8000 or even a 4000/4400/5000.
     Weekly top artists:
  • 03-03-2008 6:33 AM In reply to
    Frank Rizzo:
    THanks,
    Hi Frank!
    I didn't get the 9500, because it turned out to be a scam. I have learned my lesson, and bought a 9300 from Lifestyle AV ( very satisfied! ) this time and it just arrived today. I will move it to the house on Friday, when I get the cables for the speakers. If you are still interested, I will let you know how they sound then. And if you have already connected your speakers to the 9500, I would love to hear your experience.
    Filed under: ,
  • 03-03-2008 9:19 AM In reply to
    I'd love to hear the comparison.....are you going to connect your 9300 to the Sony amp...
     Let me know...
  • 03-03-2008 12:53 PM In reply to
    No, I'll try to connect it to the 9300 only and I hope I won't have to use the Sony amp. It will look better and be easier to use. Will tell you it goes.
  • 03-15-2008 10:58 AM In reply to
    I've connected it last week, but I just didn't get around to type something about it. So here it is.
    I've plugged it directly to the speakers, without the Sony amp. It looks way better on its own there and it sounds just as good. Well, at first I thought the Sony combination sounded a bit richer, crispier ( or something like that ), but I played around with the bass and treble settings a bit and adjusted them like they were on the Sony and I must say it really sounds just as good, if not better.
    It can easily play very loud, very clear, so I see no problems at all. That's it basically. I'm very satisfied and If you have any questions I'll be glad to answer them, but right now I'll just sit back and enjoy the music : )
  • 03-15-2008 11:03 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    gorissek:
    Is that because you have been too busy playing with your new toy to post anything.Laughing
    CraigSmile
  • 03-15-2008 12:27 PM In reply to
    Maybe... Laughing
  • 03-15-2008 2:17 PM In reply to
    f
  • 03-17-2008 3:08 PM In reply to
    did you ever get an answer to your question? if not let me know and I can tell you how to do this...
