I posted a question in regard to stylus cleaning and have results to share. Does cleaning the sapphire shaft and diamond stylus make a significant difference? The answer depends on the condition of the stylus. If the assembly is clean there is little difference, however if it is dirty, the difference is nothing less than dramatic.
My MMC2 developed a crunching noise that ruined the music experience. I found that there was debris right at the point where the shaft met the suspension. Debris removed with an artist’s paint brush and the shaft/stylus cleaned with Isopropyl alcohol corrected the problem with stunning results.
The MMC20CL on my Beogram 4000 had become “mellow” as of late but with a methodical cleaning the highs were restored and the clarity enhanced dramatically.
The NOS MMC20CL on my Beogram 4004 was relatively clean and cleaning it made only the slightest of differences.
Then on to the Beogram 4002, this turntable is the one I talk about and use the least with its unremarkable performance. Under 10X all looked normal, but under 30X the shaft was filthy and the stylus looked like it had a hornet’s nest on the tip. Cleaning transformed this Beogram into a real contender to compete with the other Beograms. The difference was like night and day!
Lastly, I cleaned the MMC6000 on my Beogram 8000 which also was quite dirty with AMAZING results. I have heard all sorts of good things about the MMC6000 and now understand the kudos lavished upon it.
So does cleaning make a demonstrable difference? If the shaft/stylus is dirty most definitely yes.
I have been warned not to touch the suspension with the alcohol and have used great care to avoid doing so. However if the shaft/stylus is sullied the effort in cleaning it is well worth the effort.
Jeff
