If I buy an IR-eye and connect it to my Beoport-box, should I be able to control iTunes with Beo4 remote? More importantly, should I be able to listen to my BS4 (audiomaster) form another room through the Beoport connected speakers (or in the case of Linkplayer, even the Macs build-in speakers)?
I gave up using the BM-link/Beoport a year ago because of too many small problems and because I have the AppleTV connected to my BV8-40 which works ok as mediacenter.
However, now this new Linkplayer seems super interesting and the BM-link has an upgrade available as well. Moreover, I'd like to be able to listen to my BS4 in the computer room and if this is possible with BM-link or Linkplayer, it is a good reason to get it back from the basement.
Sinuhe
