1st March February 2012
Latest post 02-29-2012 4:44 PM by elms. 1,786 replies.
Michael
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.25.50/avatar.jpg)
![Top 500 Contributor Top 500 Contributor](/Themes/beotheme1/images/rankicons/rankTop500.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 05-20-2009
- Glen Waverley, Victoria, Australia
- Posts 245
![Gold Member](/Themes/beotheme1/images/roleicons/d27431af-8474-494c-aeb0-d1cede4cb008.gif)
Seanie_230
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.27.38/avatar.jpg)
![Top 75 Contributor Top 75 Contributor](/Themes/beotheme1/images/rankicons/rankTop75.gif)
- Joined on 04-20-2007
- Milton Keynes, England
- Posts 962
and above
p.s Mods feel free to merge the 3 posts into one as i have no idea how to upload 3 pics in a post.
Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
Seanie_230
- Posts 962
Hi there thanks for your comment
I have the lab2 setup in projector setup only. When im on TV Speaker mode the lab 2 does not come into play.
oli
![](http://www.desmo-riders.fr/index.php?action=dlattach;attach=5;type=avatar)
![Not Ranked Not Ranked](/Themes/beotheme1/images/rankicons/rank0.gif)
- Joined on 05-10-2007
- Paris, FR
- Posts 62
![Bronze Member](/Themes/beotheme1/images/roleicons/8373aae9-2be6-4a12-8c67-ab927ce1557e.gif)
My bedroom:
![](http://nsa20.casimages.com/img/2010/08/28/100828110330723596.jpg)
oli
- Paris, FR
- Posts 62
Evan
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.06.67/avatar.jpg)
![Top 25 Contributor Top 25 Contributor](/Themes/beotheme1/images/rankicons/rankTop25.gif)
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
elephant
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.23.78/avatar.jpg)
![Top 50 Contributor Top 50 Contributor](/Themes/beotheme1/images/rankicons/rankTop50.gif)
- Joined on 04-16-2007
- Melbourne, Australia
- Posts 2,215
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
oli:
My bedroom:
Fabulous Oli
your ceiling arrangement is interesting !
and the decore is ... well fabulous
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
elephant
- Posts 2,215
Sorry for taking so long to reply; I had to have a chat with Cliff rather than rely on my memory ![Laughing](http://forum.beoworld.org/emoticons/58.gif)
As I understand Cliff's explanation, the installation team used white plastic plates that match the colour of the wall.
Two types of plates are used:
a) in the main rooms for the power and powerlink cable they used an RF aerial plate, but remove the the aerial so there was just a round hole through which they could then thread the cables
b) in Cliff's study where his Macs are, they used a plate that also had an ethernet socket
I hope that helps
Hungedu
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.32.82/avatar.jpg)
- Joined on 08-08-2009
- Ambergris Caye, Belize
- Posts 128
Is that the 46 inch BeoVision 10?
oli:
My bedroom:
BeoVision 7-55 3D, BeoSound 9000, BeoSound 8, BeoLab 7-6, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, LC-1, BeoTime (analog clock), Form 1 headphones, Beo 4 remote.
elephant
- Posts 2,215
andreabang:
you placed the beolab 2 over your furniture....i think it's a wrong position..someone can confirm?
Interesting question ... my latest addition is my week old BeoLab 11 ... and I can't decide whether to leave it on the floor, proudly on display ... or tuck it around the corner (the placement guide says to have it between the Beolab 3s), or actually place it on the cabinet between the BV8 and the BL3 (I am concerned with false reverberations)
So I would be interested in other people's options.
[ of course I could just simply "DO IT" and listen to what is sounds like ]
Dave
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.23.88/avatar.jpg)
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
Beautiful, LOVE the BL1. Wow and this is just your bedroom?>>
elephant
- Posts 2,215
Dave:
And just think ... to get out of bed in the morning he just has to crank up the volume!
Dave
- Posts 2,328
hahaha! Heaven! ![Laughing](http://forum.beoworld.org/emoticons/58.gif)
oli
- Paris, FR
- Posts 62
Hungedu:
Absolutely :)
beojeff
![](/utility/anonymous.gif)
![Top 150 Contributor Top 150 Contributor](/Themes/beotheme1/images/rankicons/rankTop150.gif)
- Joined on 11-29-2007
- Posts 543
Seanie,
We have the same projector screen. Have you had difficulty with it retracting via the 12-volt trigger? Very often, mine does not retract and I have to pull out the screen's remote and hold down on the "up" button. I wonder if this has something to do with setting the stops on the screen. I've never set the stops. Have you had any such issues?
BTW, a very light sanding with sandpaper will remove the "Panoview" lettering on the front of the screen casing without damaging the finish. I found that the screen casing is less noticeable after I sanded off the lettering.
Seanie_230
- Posts 962
Hi Beojeff
I have never had a problem with the 12v Trigger
I have the manual remote switch set to 0 and the up down set to 0 also.
I have never had any problems with it, i have not set the stops on mine as i did not know how to do it and at present it drops down level with the bottom of my bv7 screen so its perfect.
it would be good to know how to use the stops then i could set the screen to drop to just above the lab9's lense.
If the house i buy one day has a bay window i will keep this screen but if not then i will get a hidden celing one which i think will be pretty cool.
Maybe you have a naff trigger cable, buz it out with a multimeter.
Matthew
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.26.89/avatar.jpg)
- Joined on 06-01-2009
- Posts 99
elephant:
Thanks for the response Elephant. I'll have a look at this tonight and see if I can get something working. I was going to go with UK PL sockets and back boxes with an AUS mains plug sited next to it, but this is even neater.
BTW: how are you finding the BL11? This is next on my "shopping" list provided I can develop a suitable 'body of evidence' to support the purchase!
