1st March February 2012
Latest post 02-29-2012 4:44 PM by elms. 1,786 replies.
Kevin
- Joined on 03-02-2009
- San Francisco
- Posts 73
Here's a revision reflecting the new 4002/Grado
BeoSound 9000, Beolab 8000, BeoLab 4000. Beogram 4002/Grado Gold Amina conversion.
Evan
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
jldmelb:
evman140:
auclutch,
I just noticed this and I'm curious...
Is that the permanent placement for you're BeoCom 2 there next to you're bose lifestyle?
It says just above the picture: "I never got around to installing the beocom 2 so it's sitting on the table... "
Wow, haha I guess I was just properly tired when I posted that!
Jonathan
- Joined on 05-03-2007
- Melbourne, Australia
- Posts 1,164
evman140:
jldmelb:
evman140:
auclutch,
My B&O: 2009 Catalogue and Pricelist
Lex Lance
- Joined on 03-05-2010
- Posts 74
My collection from Melbourne, Australia.
Beocenter 8500 w/Beovox 50 speakers
Beosystem 4500 w/Beolab 5000 speakers.
Evan
- Ohio | USA
- Posts 2,601
LexTemplar:
I'm really admiring this! You're complete 4500 is flawless! A great combination of system and speakers
Stoney3K
- Joined on 10-26-2007
- Eindhoven, NL
- Posts 91
evman140:
I guess that'll be a pain to polish! Are the Labs going to be on the wall anytime soon?
Kevin: I really like your setup. Great combination of old and new. Is that an 8002 Gram?
Kevin
- San Francisco
- Posts 73
Stoney3K:
evman140:
Hi Stoney. Yes that was an 8002. I just sold it a couple weeks ago and a 4002 with a Grado conversion is on its way. I'll post pics once I get it.
auclutch
- Joined on 06-02-2007
- Posts 66
Yes, I know it was sad that the wall mount beocom had to sit on a table. In fact, we are redesigning our new house and the beocom's are now finding their new rooms. it's a shame that the Beocom 6000's and 2's that I have are not compatible, even with a beoline. such is life...
BS1 x 2, BS 3, BS4, BS2000 x 3, BS2300, BS4000, BS9000, BL4, BL 4000 x 2, BL8000 x 2, BL2500 x 2, BL2000, Beocom 2, Beocom 6000 x 4, Beocom 1401 x 4, Beocom 1600 x 2, Beocom 2500 x 4, Beotalk 1200, A9 Keyring, Beo4 x 8, Beotime, Bottle Opener
2011 Wish List: BL3500, BL6000, BL5, BL9, active link, BS5, Beo5
lausvi
- Joined on 04-16-2007
- Helsinki - Finland
- Posts 498
This is a great thread with some stunning photos!
Here is my Beosystem at work.
(Don't ask why, I simply have too much stuff at home so I had to expand to work and as I have my own small office room I felt that would be an ideal place to have some lighter B&O system)
Beomaster 4500 + Beogram CD4500, Beovox 3000 Flat panel -speakers. These panels do sound good but have quite a weak bass so I have attached a Genelec 1091A subwoofer (we have few of those not in use at the moment so I offered to store it on my office!) to the system and that sounds simpy stunning!)
Above the speakers I have two-part B&O 75 anniversary poster. The BM and the speakers were bought from a friend some months ago, Beogram CD from Lifestyle-AV (over eBay) and the posters from eBay.de.
Bang & Olufsen - The art of controlling sound, picture and light
Daniel
- Joined on 04-17-2007
- Svinarp, Sweden
- Posts 1,284
Ville Laustela:
Nice set up to have at work. If you get some spare time, hide the cables.
Isn´t one of the speakers upside down? Or doesn´t it matter with those?
lausvi
- Posts 498
Thanks.
I had some problems getting a suitable subwoofer cable but thanks to tournedos, I just finished it and installed today. Now I have all the cables in place I will hide the cables, they really spoil the looks.
When I bought the speakers, a friend of mine had two pairs of those for sale. I bought one pair and picked the best conditioned ones, and only much later noted they should be mirrored - I took two of the same side speakers instead! The other pair was already sold and the buyer hadn't noted that either so it's too late now. Anyway these are the better looking ones and it doesn't look bad at all having to identical ones. I can't flip one upside down as they have the BANG & OLUFSEN text on the front.
Daniel
- Svinarp, Sweden
- Posts 1,284
Ville Laustela:
Good!
Ville Laustela:
Ha, ha!  I´m sure you can´t hear any difference. And I think it´s only beoworlders who notice it.
Ehlerz
- DK
- Posts 510
avus17:
My setup
Nice setup, but i really like your bed, where is it from?
/Ehlerz
BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
lausvi
- Posts 498
Daniel:
Ville Laustela:
I suppose it's only for the symmetry, the speaker elements being furthest away from each other. In my setup the speakers are anyway just less than a meter away from each other so it doesn't really make that much difference. Also as I don't sit exactly at the center of the speakers and have to adjust balance it's really no problem.
And yes, only Beoworlders will notice!
Daniel:
Done! I just happened to find a piece of cable wrap, just long enough to hide the cables, then I fixed it to the left-side of the shelf.
Much neater now!
GuyHui
- Joined on 03-17-2007
- Posts 1,560
Hi Acanthus,
Very nice and neat set up you have in your living room.
BTW, what is the brand of your coffee table? It's very stylish.
Thanks for your reply.
Cheers,
Guy
--= "Everything gets done with Patience" =--
--= "Less is More" - Mies Van der Rohe"
--= BV10 46", BL8K, BL4K, BL2, BS Ouverture, BC6000 (Mk3), BT1100, Beo4 , A8 and ...the Atomic Floyd "Airjax+Mic" earphones =--
Stoney3K
- Eindhoven, NL
- Posts 91
Ville Laustela:
One of the speakers being the wrong way up (or, actually, the wrong side right!) will attract more attention than the "BANG & OLUFSEN" text being at the top, upside down. Nobody's going to read that anyway.
If you're really picky, you can always swap out the bezel with the bezel from a right-hand side BV3000/BL3000 speaker. There's probably some dead ones around somewhere, so any bit's worth saving from the bin. Especially when it's really shiny, polished stainless!
thavn
- Joined on 02-16-2008
- Posts 138
Judith:
The Beo4 is compatable with the Lutron Grafik Eye, which can be seen between the ladder rungs to the left of the image. The bespoke Saxum ladder is a second attempt to create a lighter ladder and the rungs were replaced and color matched with the blue anodised BeoCenter 6-23 and BeoCom2.
Wow, that was really nice. Lots of blue details! Lovely!
BV10, Avant DVD, BL5, BL4000, BS2300, BV6-26, MX 4002, 2xBeocom 6000, LC2
Evan
- Ohio | USA
- Posts 2,601
lenni:
Good to know I'm not alone...
You're space cramped with B&O is very similar to most of ours on here
