Latest post 02-14-2010 11:22 AM by joeyboygolf. 3 replies.
Page 1 of 1 (4 items)
  • 02-13-2010 3:22 PM
    Beogram 9000
    Hi...
    I am new to this site and a new owner of the Beocentre 9000.  I previously asked a question about turntables in the general forum.  Anyway...I am looking for a compatable Beogram for my Beocentre 9000...and wondered if anyone could steer me to the best direction here.
    I have looked through Ebay, with no luck at the moment.  Is the Beogram 9000 difficult to find?  Is it a good match?
    Any help would be appreciated.
    Thanks.
    Steve
  • 02-13-2010 4:14 PM In reply to
    Re: Beogram 9000
    I don't think it is a very good match - it is a standard square deck. The Beogram 3000 tangential deck has a sloping front like the Beogram 9500 and is also far easier to find. Mechanically, these decks are essentially identical.
  • 02-14-2010 7:15 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beogram 9000
    I've never understood the design of the Beogram 9000, as a match for the BC9000 it just doesn't work. As Peter has already mentioned the BG3000 is a far better match along with the BG3300. Not only are these 2 decks a better cosmetic match but they are both likely to be a fair bit cheaper & easier to find than the 9000.
    Chris.
  • 02-14-2010 11:22 AM In reply to
    Re: Beogram 9000
    At least we are all singing from the same hymn sheet!Yes -  thumbs up
    http://forum.beoworld.org/forums/t/31999.aspx
    Regards Graham
