Latest post 06-02-2010 6:24 PM by Steffen. 7 replies.
Page 1 of 1 (8 items)
  • 02-06-2010 4:14 AM
    • riis
    • Top 500 Contributor
    • Joined on 05-01-2007
    • Denmark
    • Posts 152
    How to remove front grills on Beovox M70
    When I got the M70 I tried to remove the grills in order to examine the units. I didn't succeed. I asked around in this forum, but nobody really knew. Some said that the grills might be glued to the frame, others suggested they could be screwed onto the frame. Well I didn't want to be too violent so I opened the cabinets from the back and dismantled the speakers.
    Now I have been told that the grills are attached to the frames with little plastic pins that fit into holes on the frame. I know that system from the Beovox M75, but I haven't had any problems with removing the grills on these speakers.
    So can anybody confirm that the M70 grills are attached in the same way as the M75?
    /riis
  • 02-06-2010 8:33 AM In reply to
    • riis
    • Denmark
    • Posts 152
    Re: How to remove front grills on Beovox M70
    I have checked the service manual, but unfortunately it doesn't offer much help Sad
  • 02-06-2010 2:35 PM In reply to
    • riis
    • Denmark
    • Posts 152
    riis:
    Well my memory must have played me a trick. Today I opened the cabinets again from the back, and I could see that the units were mounted from the front. So I couldn't have dismantled the speakers the last time I opened the cabinets. This recent discovery makes me sure that there must be a way to remove the fronts.
    I don't hope that the previous owner has glued the fonts to the cabinets Sad
  • 02-07-2010 4:20 AM In reply to
    • riis
    • Denmark
    • Posts 152
    Nobody? Confused
  • 02-07-2010 5:53 AM In reply to
    They come off from the front.
    Use a wallpaper scraper or wide putty knife to get in behind them.
  • 02-07-2010 3:19 PM In reply to
    • riis
    • Denmark
    • Posts 152
    casdave:
    I did it! I followed your advice and used a putty knife. The front was mounted with glue and double adhesive tape. This cannot be the way it came out of the factory. On the other hand, the front had no plastic spikes (and has never had) and there were no holes in the cabinet front to fit the spikes. I really can't figure out how it was done in the first place.
    Now I have to take away a lot of dried glue and find a way to mount the front again. What would you recommend?
  • 02-09-2010 4:39 PM In reply to
    Use self adhesive backed velcro, it was used on some speakers anyway, so you would not be too far out of spec.
  • 06-02-2010 6:24 PM In reply to
    I think there are 2 versions of the M70. The first version where the frontgrilles is glued -and a later version (before M75) with the pins/holes as seen in all later models. I once had a pair like yours with the grilles glued on -but recently I saw a set for sale on the danish QXL-site where the grilles were off -and there were those holes. (it was M70's according to the guy who had them for sale).
    Steffen
