When I got the M70 I tried to remove the grills in order to examine the units. I didn't succeed. I asked around in this forum, but nobody really knew. Some said that the grills might be glued to the frame, others suggested they could be screwed onto the frame. Well I didn't want to be too violent so I opened the cabinets from the back and dismantled the speakers.
Now I have been told that the grills are attached to the frames with little plastic pins that fit into holes on the frame. I know that system from the Beovox M75, but I haven't had any problems with removing the grills on these speakers.
So can anybody confirm that the M70 grills are attached in the same way as the M75?
/riis
