Latest post 01-24-2010 4:36 PM by Steve at Sounds Heavenly. 26 replies.
Page 1 of 2 (27 items) 1 2 Next >
  • 06-18-2007 3:49 PM
    Using a combined Masterlink & Aerial Cable
    For those people installing masterlink for use with link televisions, can I suggest you consider using a combined cable as shown below for the following reasons:-
    1. The combined Masterlink and aerial cable made by Bosscom costs less than a standard B&O Masterlink cable
    2. The cable has the same technical spec as the B&O cable, in fact they make all the B&O cables.
    3. You can also purchase a wall outlet with a combined aerial and Masterlink socket as well
    ML plus aerial
    Before anyone asks, I do not work for Bosscom
    Regards Keith....
  • 06-18-2007 4:36 PM In reply to
    Re: Using a combined Masterlink & Aerial Cable
    i wish id known about this before i started , would have saved me alot of work, [:'(]
    why didnt b+o do this in the first place?Confused
    jay
    jason
  • 06-18-2007 6:56 PM In reply to
    Thanks for the tip!
    As well on the Bosscom site: combined power cord +Powerlink.
    greg
  • 06-19-2007 1:27 AM In reply to
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    Just check to make sure the cables are suitable to your setup. You could end up using lots of connectors and fair amounts of exposed, split cable and having a poor RF link signal.
    ML is a BUS system so that extra rooms can run off by simply using ML connector boxes and convienant junctions from the one cable. B&O like you to use a single RF cable from the newer external modulators to each TV for the best signal quality. To link the cable as one won't always work.
    Beoaus.
    • kawo
    • Joined on 04-17-2007
    • Posts 516
    Keith, thank you bringing this up, I have tried to get a dealer list from them some time before, but no response.
    I really like the "power" link cable, hopefully it is the version that works with the new speakers.
    Karsten
    _________________________________________________________________________
    BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
  • 06-19-2007 2:09 AM In reply to
    As highlighted by Beoaus, if you intend to have many (greater than one) link TV's there can be a problem with long lengths of cable (greater than 30 metres because the aerial only has a single screen, so you can get reduced signal and possible interference depending on cable routing. So, going to link rooms where the cable is not to long is fine and will work perfectly, otherwise I would suggest using the B&O link amplifier.
    Regards Keith....
  • 06-19-2007 2:16 AM In reply to
    • SWISS_2
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    Lee has both the cable and Boscom Wall Socket covers for sale with LIFESTYLE AV.
    I purchased six from him last year, wired, and installed the units under the concerned gaze of my wife. I first ran each cable run per room into a PVC wall box, which the Boscom wall socket plate then covers, safe and secure. She is satisfied with the looks and outcome. This was no easy task as the walls are masonry. Wallboard would have been fair easier.
    Note that the antennae connection plugs on the Boscom sockets are single PAL. They can easily be unscrewed and changed to NTSC ( Non HD coaxial / RG 6 ) connectors for North American applications.
  • 06-19-2007 2:20 AM In reply to
    • SWISS_2
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    Keith;
    Good Morning !
    Your up early also I see. Espresso ready yet ?
  • 06-19-2007 2:53 AM In reply to
    I am drinking it now....
    Regards Keith....
  • 01-14-2009 5:39 AM In reply to
    • k984942
    • Top 500 Contributor
    • Joined on 11-10-2008
    • London, UK
    • Posts 194
    Excuse my ignorance but I'm just about to embark on masterlinking for the first time (3 Avants in a small flat).
    Is the aerial part of this cable supposed to give you tv reception from the roof aerial, or does it replace the RF cable I'd need to run between the Avants to be able to share video sources?
    32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
  • 01-16-2009 6:35 AM In reply to
    Hi everyone,
    Just a quick "spanner" to throw into the works! Devil Whilst I agree that the combined Masterlink and Aerial cable is a smart idea, I would argue that Powerlink and mains power should NOT be combined together, especially not for long cable runs.
    One of the first things you learn when studying electronics (after "don't cut the red wire"!) is that you should avoid running power and signal cables together.  This is for a very valid reason; Powerlink audio and data signals are typically less than 1 volt, whereas mains power can be up to 240 volts depending on the country of use.  Over a length of cable, the 50-60Hz frequency from the power cable will be induced into the signal wires, giving a mid-bass "buzz" through the speakers.  Conventional cable screening does little to reduce this effect.
    So, in summary, Powerlink plus mains power within one cable looks nice, but it is not a sensible solution (except as a last resort for very short cables runs).  I don't know if anyone from Bosscomm posts on this forum, but I would be interested to hear what testing has been done on this cable in terms of electromagnetic compatibility (ie. leakage of interference from the power wires into the audio wires).
    (Waiting to be shot down in flames!) Stick out tongue
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
  • 01-16-2009 7:02 AM In reply to
    Who is talking about mains combined with Masterlink/Powerlink ? You are right that you must keep mains well away from signal cables.
    Regards Keith....
  • 01-16-2009 7:21 AM In reply to
    beophiel:
    Thanks for the tip!
    greg
    Hi Keith,
    Greg's comment got me thinking, hence my post earlier.
    Best regards,
    Steve.
  • 01-16-2009 9:41 PM In reply to
    • Dave
    • Top 50 Contributor
    • Brisbane, Australia
    • Posts 2,328
    I don't know really how you can the power cable separate from the powerlink cables... with mysetup in particular all the wires run from  floor stands and to the beosound for about 3 metres... there is a hum, but it's extremely faint
  • 01-16-2009 11:18 PM In reply to
    Dave:
    good point! it is tough! ...and keep it neat!
    • B&o bottle opener
  • 01-19-2009 9:55 AM In reply to
    • k984942
    • London, UK
    • Posts 194
    My dealer says that the Bosscom's are not particularly reliable and not of great quality.
    Can anyone confirm this from personal experience?
  • 01-19-2009 10:13 AM In reply to
    • Dave
    • Posts 2,328
    k984942:
    LaughingOf course they say that! They don't make money by recommending alternative makes of their cables. Bosscom's quality is just fine with my experience and also with comments on the forum in the past.
  • 01-19-2009 10:22 AM In reply to
    Actually, Bosscom provide some products to B&O and they are a wholesale distributor, so it is unlikely they will sell products in low volumes.
    Regards Keith....
  • 03-16-2009 11:34 AM In reply to
    • dk1
    • Not Ranked
    • Joined on 05-08-2008
    • Posts 2
    There is nothing wrong with the quality of Bosscoms products, but they are not very reliable! Make sure to count the products in your order!Devil
  • 01-24-2010 3:25 AM In reply to
    Just to drag this thread up from the dead...
    I have a flat with 3 rooms.  I want to link the main room and my bedroom, but thought I'd wire up the spare room while I was at it.  To get to the bedroom, the easiest way may be to go through the spare room first.
    With this cable and some of the Bosscom wallplates, would it be possible to connect these 'serially' - i.e.:
    Main Room ----------- Spare Room ---------- Bedroom
    Or do I have to run two lengths of this?
  • 01-24-2010 3:36 AM In reply to
    You can connect Masterlink in series as you wish to do or in a star configuration or a mixture of both.
    In your situation just daisychain the masterlink from one room to the next
    Regards Keith....
  • 01-24-2010 4:31 AM In reply to
    Thanks Keith.  I think I already knew this part, so I should have been a little clearer.  I understand I can daisy chain the masterlink without issue, but using this dual masterlink/antenna cable - can I daisy chain the RF signal?  Or will I run into problems?  The total distance isn't that large, so I'm hoping that I wont!
    If I can do this, do the Bosscom RF/Masterlink wall sockets allow enough space for connecting two cables at once?
    Final question - do you know anyone who sells this cable?  I've tried, but not succeeded!  I found one online shop, but it seems to be broken (http://www.giftsaver.co.uk/acatalog/masterlink.html)
    Thanks!
  • 01-24-2010 4:49 AM In reply to
    The total distance of Masterlink cable can be up to 185 metres.
    When it comes to the 75 ohm RF video cable the story is totally different because the key is "impedance matching"
    If the cable lengths between rooms are quite short you may get away with tapping into the cable, but there will be signal quality loss.
    To ensure perfect analogue picture quality you should use a good distribution amplifier like B&O's HERE and/or a good quality splitter as shown below which will ensure good impedance matching.
    Regards Keith....
  • 01-24-2010 4:57 AM In reply to
    Thanks again Keith - if it's not plain sailing, I think I'll abandon the idea of tapping the RF in the spare room and just wire in the masterlink.  It was only for completeness:
    I have no B&O kit in that room as yet, and my future plan is to put a Beolink Active and a pair of speakers in - I don't think there's enough room for me to put a TV in there, so I doubt I'll ever bother.
  • 01-24-2010 1:21 PM In reply to
    csmager:
    I have always thought the BV6 makes a very compact satellite TV / link room speaker arrangement
    Are there second hand ones near you ?
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
