Latest post 02-14-2010 12:11 PM by beo4me. 2 replies.
Page 1 of 1 (3 items)
  • 02-01-2010 3:25 PM
    PC hangs when windows enter standby
    When Windows try to enter standby/sleep the PC hangs. The display turns off, but the PC keeps running but will not respond. It is then necessary to turn off the PC on the main power.
    I am running Windows 7 Ultimate and Beoport version 5.03 (newest).
    The most odd thing is that is worked for a week ago!
    The event log reports a critical error: Kernel Power event 41.
  • 02-10-2010 6:10 PM In reply to
    • beoblok
    • Top 500 Contributor
    • Joined on 03-19-2008
    • Finland
    • Posts 80
    Re: PC hangs when windows enter standby
          Whistle              UnsureUnsureUnsureUnsureUnsureUnsureUnsureUnsure               Whistle
  • 02-14-2010 12:11 PM In reply to
    Happened to me as well! The reason was Beoport, when I close Beoport/Beoplayer and the resident part from the icon in the status bar, the standby will work. I do not know of a workaround.
    Cheers,
    Frank
