Latest post 02-09-2010 11:55 AM by BEOCET. 11 replies.
Page 1 of 1 (12 items)
  • 02-01-2010 11:11 AM
    Problem with the XML-file for WB Electronics RE-BL PS3-adapter
    When i pres the "Power off" button on my BEO 5-remote it shuts down and reset the battery.
    I Have used the latest Config tool 3.57 and the firmware is 1.41e.
    I am the only person who has this problem?
  • 02-01-2010 12:10 PM In reply to
    Re: Problem with the XML-file for WB Electronics RE-BL PS3-adapter
  • 02-01-2010 12:31 PM In reply to
    mr_anders_son:
    3.57??
    where did you get that from???
    Yes I well like to no that too Stick out tongue
    My Bang & Olufsen....
    • BeoCenter 2 DAB/DVD mk.II
    • BeoVision 7-40 DVD mk.III
    • BeoLab Penta mk.III
    • BeoLab 4000 icepower
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beo 4 mk.I & mk.III
    • Beocom 6000
    • A8 Earphones
  • 02-01-2010 5:43 PM In reply to
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    I'm working with Config Tool V3.0 and it works.
    Which file did you use? The one from Keith? I didn't have the time to check his latest version, will try it this weekend.
    The PS3 should only power off. What do you mean by "battery reset"?
  • 02-02-2010 10:50 AM In reply to
    I used the fil from WB electronics homepage.
    Battery reset = The remote turns off and restart with no battery
    How many different files is available?
  • 02-02-2010 1:28 PM In reply to
    You can download the XML file I modified HERE for testing with the latest version of the B&O Configuration Tool.
    Regards Keith....
  • 02-03-2010 9:47 AM In reply to
    I will test the modified version from you and respond to you later.
    Thank youSmile
  • 02-04-2010 3:19 AM In reply to
    Does this Battery Reset happen every time you press Power or did it just happen once.
    If you upgrade from an old firmware version the Battery level is reset.
  • 02-05-2010 5:48 PM In reply to
    I know the battery reset can occur when you opgrade firmware. But I can tell you that the new config tool 3.57 updates your remote with new firmware(1.42a) without battery reset.
    The XML-fil I have the problem with every time I pressed Power is from WB-electronics homepage.
    But rigth now I am testing af version from Keith. And it seems to work.
  • 02-06-2010 5:59 AM In reply to
    BEOCET:
    Not mineAngry
  • 02-06-2010 11:12 AM In reply to
    guffas:
    With previous firmware updates the above statement is true. However when you update the firmware to 1.42a the battery is unaffected by the update as some members have already noted.
    Regards Keith....
  • 02-09-2010 11:55 AM In reply to
    I Have now tested your modified version 2.
    I have tested it with firmware 1.42a and the power off button works fine.
    But why have you used the makro-function to give two extra "arrow up" commands when you pres the POWER OFF button?
