I know the battery reset can occur when you opgrade firmware. But I can tell you that the new config tool 3.57 updates your remote with new firmware(1.42a) without battery reset.
The XML-fil I have the problem with every time I pressed Power is from WB-electronics homepage.
But rigth now I am testing af version from Keith. And it seems to work.
