Latest post 01-31-2010 2:32 PM by TWG. 5 replies.
Page 1 of 1 (6 items)
  • 01-28-2010 8:32 AM
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    Sony BDP-S500 XML file?
    I'm searching for a Beo 5 xml file for the Sony BDP-S500 Bluray Player.
    Does anybody has a code for this guy? I've found some Pronto files in the remotecentral forum but they only seem to be complete setups that contain the Sony BDP-S500 and many other components!?
    Thank you
  • 01-30-2010 9:11 AM In reply to
    • Quim43
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: Sony BDP-S500 XML file?
    Hi
    I have the file but I can't add it here right now. I will try later.
    Regards
    Quim
  • 01-30-2010 11:47 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    Better send me a mail and I will reply it with the file. Don't know why I can't add it here.
    Regards
    Edited: I knew I was uploaded this file already, and I found the post. You can download it from here:
    http://forum.beoworld.org/forums/t/30425.aspx
    Regards
    Quim
  • 01-31-2010 12:53 PM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    Thanks Quim!
    It works! :-)
    But there are not all buttons of the BDP-S500 in the xml file!?
    I'm missing "dimmer" for example ;-) Did you made it with the Lintronix Box and Software?
    I know, people are never 100% satisfied Big Smile
  • 01-31-2010 1:28 PM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    TWG:
    Thanks Quim!
    It works! :-)
    I am glad it works Smile
    I am not sure where I got the codes, because I haven't the bluray player. I think I found them in the Lintronic page and I converted to an xml file. If there are some missing codes, I am sorry, but I made the xml with the codes I got.
    Regards
    Quim
  • 01-31-2010 2:32 PM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    Hi Quim,
    don't take that "missing button issue" to serious; I was just joking. I'm realy happy that it works!
    I'm awaiting the "magical" Lintronic Box and I'm anxious to see if I can copy all my infrared remotes at home with that box to make the Beo 5 more useful.
    Regards!
