TWG:
Thanks Quim!
It works! :-)
But there are not all buttons of the BDP-S500 in the xml file!?
I'm missing "dimmer" for example ;-) Did you made it with the Lintronix Box and Software?
I know, people are never 100% satisfied
I am glad it works
I am not sure where I got the codes, because I haven't the bluray player. I think I found them in the Lintronic page and I converted to an xml file. If there are some missing codes, I am sorry, but I made the xml with the codes I got.
Regards
