Hi all,
Can anybody tell me what the latest software was/is for BV7 MK2?
Thanks Douglas
Mine was updated to a version called somthing with 30.a when a DVB-HD module was installed.
Ken
Hello Ken,
Are you talking about 32'' or 40'' BV7 ?
For BV7-32 here is a post http://forum.beoworld.org/forums/t/31530.aspx
O/W there is a dedicated post for firmware update http://forum.beoworld.org/forums/t/31193.aspx
Do not forget to post the improvment made and the SW number once the update has been made on your TV.
Mat
Hi, Im talking about the BV7 40" MK 1&2
Latest firmware is 7.91. for HD upgraded sets Then flash update.
If it does not have the HD ready scaler board then you need firmware 6.31
