Latest post 02-21-2010 10:20 AM by chaser. 4 replies.
Page 1 of 1 (5 items)
  • 01-28-2010 6:35 AM
    BV 7 MK1&2 software
    Hi all,
            Can anybody tell me what the latest software was/is for BV7 MK2?
    Thanks Douglas
  • 01-28-2010 7:58 AM In reply to
    • Ken
    • Not Ranked
    • Joined on 04-17-2007
    • Posts 60
    Re: BV 7 MK1&2 software
    Mine was updated to a version called somthing with 30.a when a DVB-HD module was installed.
    Ken
  • 01-28-2010 9:21 PM In reply to
    Hello Ken,
    Are you talking about 32'' or 40'' BV7 ?
    For BV7-32 here is a post http://forum.beoworld.org/forums/t/31530.aspx
    O/W there is a dedicated post for firmware update http://forum.beoworld.org/forums/t/31193.aspx
    Do not forget to post the improvment made and the SW number once the update has been made on your TV.
    Mat
  • 01-29-2010 2:07 AM In reply to
    Hi, Im talking about the BV7 40" MK 1&2
    Thanks Douglas
  • 02-21-2010 10:20 AM In reply to
    Latest firmware is 7.91. for HD upgraded sets Then flash update.
    If it does not have the HD ready scaler board then you need firmware 6.31
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
