        1st March February 2012
	    Latest post 03-31-2010 6:51 PM by  Puncher. 71 replies.
									        SwedishBeoFan
								                - Joined on 10-09-2009
								                - Posts 34
										    Re: 46-inch BeoVision 10-46 coming
										      moxxey:
That's a big jump for 6 inches of screen real estate! Nearly €4000. That can't be right? I was talking to a UK dealer and they expected the 46" to come in at £6900. The 40" is £5600, I think.
That sounds more likely. I find the article(which is not online) rather strange. It stated that the BV10 is "the ultimate TV when you can´t decide if you wan´t  to go with plasma or LCD"
I guess a reasonable pricing is a priority for B&O to keep up the success from BV10-40.
Newbie! So far: BeoVision 7 40´ Mark V Blu-ray, BeoLab 7-4, BeoLab 9, BeoSound 5,  Beo4, Beo5,  BeoCom 2, BeoTime and A8 Earphones
									        johnnielse
								                - Joined on 03-16-2009
								                - Posts 91
										      SwedishBeoFan:That sounds more likely. I find the article(which is not online) rather strange. It stated that the BV10 is "the ultimate TV when you can´t decide if you wan´t  to go with plasma or LCD"
I would very much like to read that article. Does it say anythin else of interest?
									        SwedishBeoFan
								                - Posts 34
										      johnnielse:
I think I misuse the word "article" it´s part of a piece where they present new tech-gadgets, and the BV 10-46 is featured(with a picture of the 10-40 of course). The only part of interest is the price, and they obviously  seem to have got that part wrong.
									        RWST
								                - Joined on 01-12-2010
								                - Amsterdam, NL
								                - Posts 50
										    Hi all,
I just checked with my local dealer in Zurich, the BV10-40" is around CHF 8000, he expects the BV10-46" to come around CHF 3000 more, so at around CHF 11.000.
When I checked with my dealer in Amsterdam, the BV10-40" is around EUR 5400, and he expected the BV10-46" to be EUR 2000 more, so at around EUR 7500
With currenct exchange rate of EUR/CHF at 1.4655, I think it is safe to assume that the BV10-46" will be priced around EUR7500/CHF 11.000
I don't know the U.S. prices.
Regards
									        deejoa
								                - Joined on 08-27-2009
								                - Posts 27
										    Sounds great, RWST. Thanks!
									        johnnielse
								                - Posts 91
										    Thank you RWST.
That sounds more fair.
									        GuyHui
								                - Joined on 03-17-2007
								                - Posts 1,560
										    Thanks too RWST for the estimated price of the BV10 46".
7500 euros was the price (approximatively) of the former Avant DVD 32".
Cheers,
Guy
									    --= "Everything gets done with Patience" =--
--= "Less is More" - Mies Van der Rohe"
--= BV10 46", BL8K, BL4K, BL2, BS Ouverture, BC6000 (Mk3), BT1100, Beo4 , A8 and ...the Atomic Floyd "Airjax+Mic" earphones =--
									        Marco6474
								                - Joined on 06-19-2007
								                - Biarritz -
								                - Posts 99
										    I've already upgraded my BV 7-32 to a BV 10-40, thinking a larger screen wouldn't be available within the year. The 46" screen will be more appropriate in my living. I'll try to negociate a change.
Does anyone know the dimensions? I supposed it could be around 1,20 x 1,20 m. Do you also knowif the wall bracket will be the same for both versions?
Cheers, Marc.
									        RWST
								                - Amsterdam, NL
								                - Posts 50
										    Hi Marc,
Concerning the wall bracket, according to my dealer in Zurich, the wall bracket will not be uniform for the BV10-40" and "46.
Dimension wise it is rather difficult to tell the size, although the ratio for both the 40" and 46" is expected to remain the same, so do the math.
Regards
									        Marco6474
								                - Biarritz -
								                - Posts 99
										    Thanks for your answer. I was hoping for the same wall bracket, which could let me change easier.
Kind regards, Marc.
									        RWST
								                - Amsterdam, NL
								                - Posts 50
										    It wouldn't stop you to buy the 46", would it ;-)
									        johnnielse
								                - Posts 91
										    I heard that B&O will officially unveil the BV10-46 in mid-April.
									        macsat
								                - Joined on 04-17-2007
								                - Posts 40
										    According to a normally quite good source, the retail price in Denmark including a Beo4 and DVBHD will be 54990 DKK excluding the anti-glare and 61995 DKK including the anti-glare coating.
The current price for BV10-40 in Denmark is 43495 and 48995 for the versions without and with the coating.
This indicates a 26% priceincrease over the 40 inch.
									        RWST
								                - Amsterdam, NL
								                - Posts 50
										    Hi Johnnielse,
My official B&O dealer in Zurich confirmed this date as well.
Can't hardly wait!
Regards
									        johnnielse
								                - Posts 91
										      RWST:
Hi Johnnielse,
Can't hardly wait!
Regards
Yeah, I also had it confirmed by B&O themselves and a dealer. So it sound very plausible
It'll be interesting. According to what I heard the BV10-46 looks a bit wider although it's not. I'ts probably because if the speaker grille.
									        Harry2008
								                - Joined on 11-09-2008
								                - Netherlands
								                - Posts 252
										      Marco6474:Does anyone know the dimensions? I supposed it could be around 1,20 x 1,20 m. Do you also knowif the wall bracket will be the same for both versions?
Dimensions of the bv10-46 are bxhxd 114 x 103.5 x 6.9 including bracket.
Above that my dealer confirmed that pricing in NL will be between 7500 and 8000 euro.
									        TripEnglish
								                - Joined on 10-27-2007
								                - America
								                - Posts 1,595
										      jk1002:
When you look at the new audio system how it was described in the last years financial report it said that it links to an Ipod or a Beosound 5 system.
I 2nd the 2 way remote, but I am thinking they first should spend some time gather feedback what people really want from a BS5.
For example, MOTS within category to filter out holiday themed songs and gapless playing for concerts, classic and DJ mixes without gaps for non windows media file formats.
There is probably more from people who actually bought that thing, I am still holding my breath for the above, I could maybe live without a 2 way remote for a little longer.
I think that anyone who like the BeoSound 5 but has certain reservations about missing features or is unsatisfied with some of the way it handles certain things will be assuaged within the next few months.
  I think that people who are concerned that there is no viable way to interface with the BeoSound 5 in link rooms will be assuaged by fall.
I don't know why I think these things. I just do sometimes.
									    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
									        linder
								                - Joined on 04-16-2007
								                - Posts 653
										      TripEnglish:
  jk1002:
Its true MOTS does put Christmas music in the playlist.  However its just like taking down the Christmas tree after the holidays.  I deleted the Christmas music.
Trip.  I hope the music system has a place for me to plugin a Beogram 7000 besides the Beosound 5.  I don't want to get too digital!
									    Beosound 5 BL9 BC2 BL8000 Beovision 7 BL6002  BL11
									        Dave
								                - Brisbane, Australia
								                - Posts 2,328
										      linder:
"Tell him he's dreamin'!!"
									        TripEnglish
								                - America
								                - Posts 1,595
										      Dave:
  linder:
There will be a spindle for a wax cylinder. You can access by pressing A.WAX
									        linder
								                - Posts 653
										      TripEnglish:
  Dave:
  linder:
Maybe you press B.WAX!  Of course it will work along with other devices.  PhilLondon's explanation is very clear.  Its a wifi enabled spec that should map to any connection including for example A.AUX on a Beosound 9000 or BCS.  In this case IR doesn't matter.  Besides iPhone, it should work with iPod touch and probable with the iPad.  Look at the thread about the iPhone controlling the new gateway Official: iPhone to controle B&O equipment!
