Hi
Can any forum members help? I need to replace the foam for the larger of the two speakers in this unit. The speaker fixing plate measures 100mm x 100mm or 4" x 4". The foam diameter is 80mm approximately.
Thanks.
Hi!
In Finland 170€ for two.
regards
Hi Hagan
Thanks for your reply. Where in Finland can I contact a B&O (type6344) speaker foam seller.
Sorry for the delay in replying.
Denzil
The price I mentioned was for completely new drivers including foam surround. You can order them from any local B&O dealer
best regards
Thanks once again, your prompt and good advice is much appreciated.
Regards.
I believe I paid somewhere around 65-70€ for a pair of woofers here in Sweden.
The old ones were sent to Germany for a new life there...
Hi Fridsten
Thanks for your very useful information.
However, I'm still working on the idea of replacing the foam rings on my existing speakers, to retore the units to a clear and clean sound output.
