Latest post 06-27-2007 1:52 AM by denzil14. 7 replies.
Page 1 of 1 (8 items)
  • 06-18-2007 4:12 AM
    B&O Beovox CX50 speakers (Type 6344).
    Hi
    Can any forum members help?  I need to replace the foam for the larger of the two speakers in this unit. The speaker fixing plate measures 100mm x 100mm or 4" x 4".  The foam diameter is 80mm approximately.
    Thanks.
  • 06-18-2007 4:17 AM In reply to
    Re: B&O Beovox CX50 speakers (Type 6344).
    Have a look at ebay, they are offered there regularly. On the other hand the drivers are still available from B&O and not that expesive - I'm sure some members know the exact price.
  • 06-18-2007 4:56 AM In reply to
    Hi!
    In Finland 170€ for two.
    regards
  • 06-25-2007 8:03 AM In reply to
    Hi Hagan
    Thanks for your reply. Where in Finland can I contact a B&O (type6344) speaker foam seller.
    Sorry for the delay in replying.
    Denzil
  • 06-25-2007 8:10 AM In reply to
    Hi!
    The price I mentioned was for completely new drivers including foam surround. You can order them from any local B&O dealer
    best regards
  • 06-26-2007 12:01 PM In reply to
    Hi Hagan
    Thanks once again, your prompt and good advice is much appreciated.
    Regards.
    Denzil
  • 06-26-2007 3:58 PM In reply to
    • fridsten
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Stockholm, Sweden
    • Posts 167
    I believe I paid somewhere around 65-70€ for a pair of woofers here in Sweden.
    The old ones were sent to Germany for a new life there...
  • 06-27-2007 1:52 AM In reply to
    Hi Fridsten
    Thanks for your very useful information.
    However, I'm still working on the idea of replacing the foam rings on my existing speakers, to retore the units to a clear and clean sound output.
    Regards.
    Denzil
