Latest post 02-27-2010 5:48 AM by chartz. 17 replies.
Page 1 of 1 (18 items)
  • 01-23-2010 11:38 PM
    Dust Cover "Stops"?
    At the front of the dust cover for my Beogram 1800 (later model), there were two tiny black plastic stops (what the service manual calls them) at either corner that acted as a sort of buffer/space filler between the plastic of the cover and the aluminum of the top plate. Mine are both gone and as a result there's room between the cover the top plate in the front. My question: Has anyone ever found a good substitute for the stops? I'm looking for something that's as close as possible to what was originally there, which from the service manual looks almost like an upside down spike, with the pointy end going up into a hole in the corner of the cover and the "head" being the part that touches the top plate.
  • 01-24-2010 7:37 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Dust Cover "Stops"?
    Have you asked B&O ?
    I am almost sure that they are still available as they are used several places.
    Aren't they also found under the Beolink 1000 and similar remotes ?
  • 01-24-2010 8:54 AM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    I may have an old dust cover somewhere with these on - I'll have a look....
    What sort of condition is your cover in? Mine may be better & if so you can have the whole thing.
    Chris.
  • 01-24-2010 10:19 AM In reply to
    Given how old these covers are, I'm not sure what would seem good or bad for the age. Mine has a fair amount of hairline scratches on it, and one of the plastic tabs on the inside near the hinges is broken, but otherwise it's functional and looks ok.
    Matt
  • 01-24-2010 11:39 AM In reply to
    Dillen:
    Hmmm... I was wondering the same thing... they sure seem to be very similar! Surely, they would be worth a try and are probably available for order from a dealer.
    • B&o bottle opener
  • 01-25-2010 9:23 AM In reply to
    There's a B&O dealer not too far from where I live. I'll call and see if they have these things. My only concern is being able to explain what it is I'm talking about. . . . Stay tuned.
  • 01-25-2010 1:12 PM In reply to
    No luck. Dealer said they don't sell parts to anything. I also saw on the B&O site where it says they don't sell "spare parts" to consumers; you have to get the item in question serviced.
  • 01-25-2010 2:11 PM In reply to
    • Medogsfat
    • Posts 4,045
    Not good news from me either I'm afraid, I have found the lid I have and the rubber stops are missing - sorrySad
    Chris.
  • 01-25-2010 5:54 PM In reply to
    Thanks for checking Chris.
  • 01-25-2010 6:42 PM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Surely, if they are the same as the feet on a Beolink 1000, they are still available from dealers!
    Poor me, never win owt!
  • 01-25-2010 8:16 PM In reply to
    So like I said. . . the dealer told me, no, they don't have them, because they don't sell any parts. Maybe the policy is different in other countries, but I was told that I'd have to bring the turntable in and have their service tech "fix" it in order to get the parts. Or I suppose I could just buy a new Beolink 1000, but that doesn't seem very cost effective. Wink
  • 01-25-2010 8:25 PM In reply to
    I knew this rang a bell! LaughingLaughingLaughing
    Look here!
    • B&o bottle opener
  • 01-26-2010 2:58 AM In reply to
    • Dillen
    • Posts 5,008
    The new feet for the Beolink 1000 has tiny inside pulling "stabs" so I don't think they are the same, at least not any longer.
    The rubber stops part number is 3010007 and they are widely used in turntables (1800/4002 etc.).
    I suggest you phone another dealer. I will ask mine too.
  • 01-26-2010 9:35 AM In reply to
    Thanks, Martin. I'll try a few other dealers and see if they're more helpful than the first.
  • 01-26-2010 2:58 PM In reply to
    Martin and Jandyt were right: I got a helpful salesperson at the B&O store in NYC and he ordered the stops today. I'll have them Friday. Thanks for the prodding to pursue the store route. And Martin, a special thanks for tracking down the part number.
  • 01-26-2010 3:09 PM In reply to
    • chartz
    • Top 75 Contributor
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    I'm interested too. Are these the same on the Beogram 8000 cover? CDX/CDX2/CD-3300 CD players?
    Thanks,
    Jacques
    Jacques
  • 01-26-2010 5:47 PM In reply to
    • Dillen
    • Posts 5,008
    They are not separately listed in my manuals but I think they are the same.
  • 02-27-2010 5:48 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Hello,
    I finally got the rubber stops from a nice dealer, 1.25 € each, but if they obviously fit perfectly on my BG turntables, the ones on the CDX and CD-3300 are different (the holes are much bigger) so they have to be glued in place...
    Does anyone have the actual references for the CD player ones?
    Jacques
