1st March February 2012
Latest post 02-27-2010 5:48 AM by chartz. 17 replies.
01-23-2010 11:38 PM
Dillen
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.31/avatar.jpg)
![Top 10 Contributor Top 10 Contributor](/Themes/beotheme1/images/rankicons/rankTop10.gif)
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
Have you asked B&O ? I am almost sure that they are still available as they are used several places. Aren't they also found under the Beolink 1000 and similar remotes ?
Medogsfat
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.35/avatar.jpg)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
I may have an old dust cover somewhere with these on - I'll have a look....
What sort of condition is your cover in? Mine may be better & if so you can have the whole thing.
Chris.
dbxdx5
![](/utility/anonymous.gif)
![Not Ranked Not Ranked](/Themes/beotheme1/images/rankicons/rank0.gif)
- Joined on 06-09-2009
- Posts 65
![Bronze Member](/Themes/beotheme1/images/roleicons/8373aae9-2be6-4a12-8c67-ab927ce1557e.gif)
Given how old these covers are, I'm not sure what would seem good or bad for the age. Mine has a fair amount of hairline scratches on it, and one of the plastic tabs on the inside near the hinges is broken, but otherwise it's functional and looks ok.
Matt
burantek
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.31.44/avatar.jpg)
- Joined on 05-04-2007
- SE USA
- Posts 6,214
Dillen:Aren't they also found under the Beolink 1000 and similar remotes ?
Hmmm... I was wondering the same thing... they sure seem to be very similar! Surely, they would be worth a try and are probably available for order from a dealer.
Medogsfat
- Posts 4,045
Not good news from me either I'm afraid, I have found the lid I have and the rubber stops are missing - sorry![Sad](http://forum.beoworld.org/emoticons/06.gif)
Chris.
Dillen
- Posts 5,008
The new feet for the Beolink 1000 has tiny inside pulling "stabs" so I don't think they are the same, at least not any longer. The rubber stops part number is 3010007 and they are widely used in turntables (1800/4002 etc.). I suggest you phone another dealer. I will ask mine too.
chartz
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.30.99/avatar.jpg)
![Top 75 Contributor Top 75 Contributor](/Themes/beotheme1/images/rankicons/rankTop75.gif)
- Joined on 07-20-2009
- Burgundy
- Posts 984
![Gold Member](/Themes/beotheme1/images/roleicons/d27431af-8474-494c-aeb0-d1cede4cb008.gif)
I'm interested too. Are these the same on the Beogram 8000 cover? CDX/CDX2/CD-3300 CD players?
Thanks,
Jacques
Dillen
- Posts 5,008
They are not separately listed in my manuals but I think they are the same.
chartz
- Burgundy
- Posts 984
Hello,
I finally got the rubber stops from a nice dealer, 1.25 € each, but if they obviously fit perfectly on my BG turntables, the ones on the CDX and CD-3300 are different (the holes are much bigger) so they have to be glued in place...
Does anyone have the actual references for the CD player ones?
Page 1 of 1 (18 items)
