Latest post 02-27-2010 3:44 PM by scanorama99. 5 replies.
Page 1 of 1 (6 items)
  • 01-21-2010 6:33 PM
    Other options than bm-link and linkplayer?
    If I have beoport are there other options than linkplayer and bm-link in terms of an easy navigated app that can for example control frontrow, itunes, plex, dvd player like linkplayer do ?
    I cant manage to make linkplayer work so is there other options?
    I would really love a replica of the beomedia interface since I think it looks really mac-like/elegant with the moving/rotating sliding menus as I have seen on my pc
  • 01-21-2010 8:19 PM In reply to
    Re: Other options than bm-link and linkplayer?
    scanorama99:
    I am sorry you can't get LinkPlayer to work ... did you try sending Phillipe the diagnostics as I suggested elsewhere ?
    I have replied to your other post on BeoVRC http://forum.beoworld.org/forums/p/5222/254321.aspx#254321
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 01-22-2010 12:21 PM In reply to
    Yes I did
    It screws up my itunes pretty badly, so that I cannot use itunes after the first time I run linkplayer. Only solution is to completely reinstall itunes and dont run linkplayer again. Arrgh! Why me! :)
  • 01-22-2010 12:29 PM In reply to
    scanorama99:
    Yes I did
    Seems more like a bad Itunes plug-in of some kind causing the problem.
    Link players performs excellently in my setup.
  • 02-26-2010 5:37 PM In reply to
    you could email David Charles and ask him to send you his  MyBeoPort application
    could be worth a try, his software works without needing a B&O Audio Master in the masterlink systeml, which is a bonus for some people  :-)
  • 02-27-2010 3:44 PM In reply to
    hmm.. that looks like a nice app, thanks!
