hello i have done some reading on the main site under products and BV1
It says that the BV1 is availible in LS version also.
is it correct that the normal bv1 is controlled by a beo1 and a BV1 LS is controlled via a Beo4.
can the BV1 be controlled by a beo4?
also it says the BV1 LS cannot have the STB controller installed.
can the normal one access Sound from the main room as it says the normal one is a main room tv??/
Beovision 7 MKIV (Blu Ray)
Beolab 9
Beolab 6000
Beo 4
Beocenter 9300
Apple TV
SKY HD
Optoma HD65 Projector
Lintronic TT455-RT-238
Beovision 3 MKII
