Latest post 01-23-2010 11:45 AM by vikinger. 9 replies.
Page 1 of 1 (10 items)
  • 01-21-2010 11:25 AM
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    What TV
    Hello All
    i have a BV7 in my main room and i woudl like to add a bedroom TV
    the link tv woudl need to have a STB controller that can control Sky (Normal)
    also be able to select AV V.Mem which i have my apple tv connected to just for audio.
    What TV supports AV V.Mem and STC control
    i looked and i see MX4000 go cheap now do these do what i need?
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 01-21-2010 11:35 AM In reply to
    Re: What TV
    Are you you using the Sky box in the bedroom or are you using the one in the main room? You can control the box in the main room from the bedroom from almost any set - I use an LX6000 which has no STB-C as you are actually using the STB-C in the main room set. The problem you may have if you want to control a bedroom Sky box is getting the STB card for an MX. They are not available officially any more so you need a set with one fitted already.
  • 01-21-2010 2:04 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: What TV
    hi Peter yeah sorry i want to be able to control a seperate sky box connected in the bedroom just for freeview as i dont really bother with link room video.
    If not an MX with Sky conrtol in the range of other smaller TV's (second hand) will work with masterlink (AV V.MEM) and STB?
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 01-22-2010 5:17 AM In reply to
    Re: What TV
    I don't think you should have an issue with any set as long as you can get the STB-C. Just look out for one that has it already fitted. The MX1500 is a non starter. The MX is, as you have already worked out, the obvious choice. A BV1 with the ML connection would be another.
  • 01-22-2010 8:27 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: What TV
    does all older tv's support V.MEM command?
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 01-22-2010 11:14 AM In reply to
    Re: What TV
    V.MEM is the same command as V.TAPE, so yes!
  • 01-22-2010 2:16 PM In reply to
    • hilde
    • Not Ranked
      Female
    • Joined on 04-22-2009
    • germany
    • Posts 34
    Re: What TV
    hi peter,
    are you shure that the stb's controllers are not available ?
    three weeks before x-mas my dealer installed one in an old avant vtr an
    the other one in an old mx7000 with two new software IC's (version 4/19).
    i spent / sold the tv's for the controllers price to a friend.
    with kind regards
    SERENE
  • 01-22-2010 2:18 PM In reply to
    Re: What TV
    The Avant one is still available but the one for the AV9000/MX seems trickier to find.
  • 01-22-2010 4:15 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: What TV
    hello i have done some reading on the main site under products and BV1
    It says that the BV1 is availible in LS version also.
    is it correct that the normal bv1 is controlled by a beo1 and a BV1 LS is controlled via a Beo4.
    can the BV1 be controlled by a beo4?
    also it says the BV1 LS cannot have the STB controller installed.
    can the normal one access Sound from the main room as it says the normal one is a main room tv??/
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 01-23-2010 11:45 AM In reply to
    Re: What TV
    Seanie:
    Hi Seanie,
    Later BV1's and BC1's came with Beo4 which I think also works on the earlier models. I use a BC1 as a stand alone TV separate from my Avant. It has the advantage of the  built-in DVD and a very adequate sound system, plus FM radio. (Bought it from a guy who originally had it working as a link from a BV6 with Sky if I wasn't mistaken.)
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
