I have tried to connect as you discribed MartinW. And it works fine. If I try to disconnect the SPDIF then no sound, so it uses the SPDIF.
Al this is when i press PC on the remote, when pressing CD (N.Music) then it sounds like it is switching back to masterlink again.
I had hoped that it kept on using the SPDIF, but it doesn't seem so. There are differences in the music using the one (PC / SPDIF) versus the other (CD / MasterLink), but my ears are not qualifyed to describe what they are.
I just assumed a better signal was obtained by keeping the signal digital as long as possible.
One could start discussing the differnece between the D/A converter in the BeoMaster 5 and in the BeoVision 7 versus transporting the signal analouge via MasterLink.
I also agree with MartinW that it is great beeing able to see the cover of what is playing, as you can when playing via PC on BV7. But in my case I have placed the BeoSound 5 so it can be seen from the listening position, so the cover is always visible here.
Thanks for your input.
/MiakelB
