Latest post 02-20-2010 2:58 PM by Leslie. 6 replies.
Page 1 of 1 (7 items)
  • 01-12-2010 1:52 PM
    part for LC2 lightdimmer
    I'm looking for a part (strain relief) that belongs to a LC2 lightdimmer.
    Anyone who can supply me this little part?
    Thanks in advance! Leslie
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 02-02-2010 3:53 PM In reply to
    Re: part for LC2 lightdimmer
    Nobody who has this little part? Sad Or a defect LC2 for sale?
  • 02-04-2010 6:09 AM In reply to
    • geearr
    • Top 200 Contributor
    • Joined on 03-27-2008
    • Gold Coast, Australia
    • Posts 301
    • Gold Member
    Hi Leslie
    You don't seem to be having much luck getting the part that you want.  Since you already have one at one side of the LC2 that you can use as a template, have you thought about hand carving something yourself.  After all, it is only a simple cable clip that needs to fit into that special shaped opening and it doesn't have to look too flash.  Two pieces of plastic (perspex) and a set of small nuts and bolts would do the trick.  At least you would have your LC2 back in operation fairly quickly.
    Have fun
    Geoff
  • 02-04-2010 6:16 AM In reply to
    Hi Geoff,
    Never thought of that, that could be the trickSmile
    Thank you very much, lots of good responses I get from "down under"!Travel
  • 02-08-2010 1:10 PM In reply to
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    Leslie:
    I have been following this topic for a while nowWhistle
    Now it's dead I really could use the parts, see my topic http://forum.beoworld.org/forums/t/31354.aspx
    If you are planning to sell itGift?
    Sure, once the insurance co. have done their stuff I'll strip it for spares. P.M. me.
  • 02-15-2010 5:47 PM In reply to
    Any updates? Thanks!
  • 02-20-2010 2:58 PM In reply to
    Finally guys!
    Thanks to Gert Jan from Summa455.nl he gave me more then what I've asked for (twice). Without any cost...
    This is what I call true membershipYes -  thumbs up
