I'm looking for a part (strain relief) that belongs to a LC2 lightdimmer.
Anyone who can supply me this little part?
Thanks in advance! Leslie
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Nobody who has this little part? Or a defect LC2 for sale?
Hi Leslie
You don't seem to be having much luck getting the part that you want. Since you already have one at one side of the LC2 that you can use as a template, have you thought about hand carving something yourself. After all, it is only a simple cable clip that needs to fit into that special shaped opening and it doesn't have to look too flash. Two pieces of plastic (perspex) and a set of small nuts and bolts would do the trick. At least you would have your LC2 back in operation fairly quickly.
Have fun
Geoff
Hi Geoff,
Never thought of that, that could be the trick
Thank you very much, lots of good responses I get from "down under"!
Leslie: I have been following this topic for a while now Now it's dead I really could use the parts, see my topic http://forum.beoworld.org/forums/t/31354.aspx If you are planning to sell it?
Sure, once the insurance co. have done their stuff I'll strip it for spares. P.M. me.
Any updates? Thanks!
Finally guys!
Thanks to Gert Jan from Summa455.nl he gave me more then what I've asked for (twice). Without any cost...
This is what I call true membership
