Latest post 01-12-2010 3:06 PM by glug. 13 replies.
Page 1 of 1 (14 items)
  • 01-09-2010 3:03 PM
    • glug
    • Not Ranked
    • Joined on 06-19-2008
    • Posts 27
    Beolab 9 with Beovision 5, compatible or not?
    The BV5 does not have the BL9 in its menu of compatible speakers, probably due to its age?
    Is there an upgrade to the BV5 to allow the use of BL9 or should BL9 be used with BL1 or BL5 selected from the menu?
    Many thanks.
    G
    Beovision 5 HD, Beo5, Avant x2, BL9, BL8000 x2, Beosound 1, BL2, Beosound 9000, Beocom2, Beogram 3000 , A8.
  • 01-09-2010 3:17 PM In reply to
    Re: Beolab 9 with Beovision 5, compatible or not?
    I would select Beolab 5. There probably is an upgrade though I doubt it will add anything important.
  • 01-09-2010 3:25 PM In reply to
    • glug
    • Not Ranked
    • Posts 27
    So, not a big deal, enjoyment wise?
    I was considering buying BL5s to keep the configuration tidy but if I'm not losing anything with the menu mismatch I'll probably stick.
    Cheers
    G
  • 01-09-2010 4:21 PM In reply to
    • Toubro
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 263
    I had a couple of BL3's connected to my Avant as BL8000's, and they played wonderfully, so it shouldn't be a problem.
  • 01-09-2010 7:44 PM In reply to
    My BV5 don't have BL5, I have it set to Beolab Penta. Works great.
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 01-09-2010 8:39 PM In reply to
    I'd probably go ahead and get the BeoLab 5s just to be on the safe side
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 01-10-2010 3:50 AM In reply to
    glug:
    Many thanks.
    G
    There isn't an upgrade to have BeoLab 9's in the menu, but the B&O recommendation is use the setting for BeoLab 1 because the BeoLab 9 is based on the BeoLab 1 chassis.
  • 01-10-2010 4:47 AM In reply to
    • glug
    • Not Ranked
    • Posts 27
    I'd probably go ahead and get the BeoLab 5s just to be on the safe side Wink
    Big Smile That's just the way my tiny mind works, even when I can't afford stuff.
    meandmyshadow:
    glug:
    Many thanks.
    G
    Peace of mind reigns. Lab 1 setting it will be.
    Many thanksYes -  thumbs up
  • 01-11-2010 3:06 PM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    TripEnglish:
    Yes, and a BV9 to be really safe. Smile
  • 01-11-2010 3:37 PM In reply to
    bayerische:
    Which software does your sound module (and chassis) have?
    Even the avant 32 RF DVD (8450 type mkII) had the "BL 5" option.
  • 01-11-2010 3:38 PM In reply to
    • glug
    • Not Ranked
    • Posts 27
    Daniel:
    TripEnglish:
    Please don't tempt me.
    I'd look a bit sad sitting on the pavement watching my blank BV9 and listening to my silent BL5s having lost the house to the bank.
    I have Beomania.Big Smile
  • 01-11-2010 5:17 PM In reply to
    I would strongly recommend a home demo before you buy.
    When I connected my BL3s direct to my BV8 rather then to my BC2 I noticed a huge difference in sound when playing CDs. in fact I am not using my BL3s anymore for watching TV.
    Giving the amount of money you are about to drop, I ask the dealer about it.
    Cheers
    JK
  • 01-11-2010 5:22 PM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    glug:
    That would definitely qualify you for the BeoAddict thread. Big Smile
  • 01-12-2010 3:06 PM In reply to
    • glug
    • Not Ranked
    • Posts 27
    jk1002:
    Cheers
    JK
    So is it worth connecting my BL9s direct to my BS9000 for improved CD performanceConfused
    G
