1st March February 2012
Latest post 01-12-2010 3:06 PM by glug. 13 replies.
01-09-2010 3:03 PM
glug
- Joined on 06-19-2008
- Posts 27
Beolab 9 with Beovision 5, compatible or not?
The BV5 does not have the BL9 in its menu of compatible speakers, probably due to its age?
Is there an upgrade to the BV5 to allow the use of BL9 or should BL9 be used with BL1 or BL5 selected from the menu?
Many thanks.
G
Beovision 5 HD, Beo5, Avant x2, BL9, BL8000 x2, Beosound 1, BL2, Beosound 9000, Beocom2, Beogram 3000 , A8.
Peter
- Joined on 02-12-2007
- Posts 9,572
Re: Beolab 9 with Beovision 5, compatible or not?
I would select Beolab 5. There probably is an upgrade though I doubt it will add anything important.
glug
- Posts 27
So, not a big deal, enjoyment wise?
I was considering buying BL5s to keep the configuration tidy but if I'm not losing anything with the menu mismatch I'll probably stick.
Cheers
G
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
My BV5 don't have BL5, I have it set to Beolab Penta. Works great.
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
TripEnglish
- Joined on 10-27-2007
- America
- Posts 1,595
I'd probably go ahead and get the BeoLab 5s just to be on the safe side
There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
meandmyshadow
- Joined on 04-17-2007
- Posts 339
glug:
Many thanks.
G
There isn't an upgrade to have BeoLab 9's in the menu, but the B&O recommendation is use the setting for BeoLab 1 because the BeoLab 9 is based on the BeoLab 1 chassis.
glug
- Posts 27
That's just the way my tiny mind works, even when I can't afford stuff.
meandmyshadow:
glug:
Many thanks.
G
Peace of mind reigns. Lab 1 setting it will be.
Many thanks
Daniel
- Svinarp, Sweden
- Posts 1,284
TripEnglish:
Yes, and a BV9 to be really safe.
Beobuddy
- Joined on 04-18-2007
- Posts 1,582
bayerische:
Which software does your sound module (and chassis) have?
Even the avant 32 RF DVD (8450 type mkII) had the "BL 5" option.
glug
- Posts 27
Daniel:
TripEnglish:
Please don't tempt me.
I'd look a bit sad sitting on the pavement watching my blank BV9 and listening to my silent BL5s having lost the house to the bank.
I have Beomania.
jk1002
- Joined on 04-16-2007
- Boston USA
- Posts 1,620
I would strongly recommend a home demo before you buy.
When I connected my BL3s direct to my BV8 rather then to my BC2 I noticed a huge difference in sound when playing CDs. in fact I am not using my BL3s anymore for watching TV.
Giving the amount of money you are about to drop, I ask the dealer about it.
Cheers
JK
Daniel
- Svinarp, Sweden
- Posts 1,284
glug:
That would definitely qualify you for the BeoAddict thread.
glug
- Posts 27
jk1002:
Cheers
JK
So is it worth connecting my BL9s direct to my BS9000 for improved CD performance
G
Page 1 of 1 (14 items)
