Overall I like the design.
A few things I find to be so troublesome I'd never buy it:
It's 18 inches. Eighteen!! Add to that the speakers, and you have a monstrosity never to be carried anywhere.
Given the size and propable use, I can't help but wonder why on earth it's got a 1.7GHz processor - albeit an i7.
Another thing: I moved from Apple's laptops to Thinkpads. One of the "heavy" reasons was the trackpoint, and when Apple made their touchpads even bigger, resulting in even more hurt in the long run, I figured a Thinkpad X200s was the way to go (trackpoint only - no touchpad at all)
Aaanyway, they "sell" this with two touchpads so one can play "dj" on them. what use would that be for the rest of us? Seriously?
No, personally I find that product to be all gimmick, no substance. I do like how the speakers look, though (this coming from someone who has a mone speaker at the bottom of his computer and mostly use headphones).
Edit:
I just realised where the touchpads are:
They are to the left and right of the keyboard. Speaking of ergonomics, that is propably the worst place for such things as you will have to use your hand the most to get there as opposed to a trackpad below or a trackpoint in the middle.
All in all, I figure Lewis forgot the golden rule: If it works, keep it, and if it aint' broken, don't fix it.
/end edit.
