Latest post 01-04-2010 12:31 PM by beojeff. 5 replies.
Page 1 of 1 (6 items)
  • 01-04-2010 10:09 AM
    • js
    • Top 500 Contributor
    • Joined on 09-07-2007
    • Brussels
    • Posts 208
    • Silver Member
    Beomaster 7000 external IR sensor
    Dear all, the Beomaster 5500 has a 6 pin DIN socket for connecting the external IR sensor type 2001. Very useful in large rooms or when hidden in a cabinet.
    Does the Beomaster 7000 have a similar connection? In other words: is there a way to connect an external IR sensor to a Beomaster 7000 for use in the main room (i.e. without using a MCL2A)? And should sensor type 2001 or another type be used here?
    Thanks a lot for your help. Kind regards, js
  • 01-04-2010 10:20 AM In reply to
    Re: Beomaster 7000 external IR sensor
    While not the same as the Beomaster but in the same family, I know that the AV 7000 can use an external IR eye. However, I have heard of instances of using the external IR eye blowing a fuse in the AV7000.
  • 01-04-2010 10:23 AM In reply to
    There's no such connector on Beomaster 6500, so I don't suppose it would've been brought back for 7000. The Powerlink connectors (and the separate TV/AUX connector) take up the space that used to be in the connector bay for stuff like the sensor socket.
    So there's no off the shelf solution, but it would not be too difficult to hook up a TSOP7000 IR receiver in parallel with the receiver circuit already in the Beomaster. No two way then of course, and in my experience the integrated modules don't quite match the B&O circuitry in receiving range.
    In addition, why would anyone want to hide a BM7000 in a cabinet? Stick out tongue
    -mika
  • 01-04-2010 10:24 AM In reply to
    • js
    • Brussels
    • Posts 208
    • Silver Member
    beojeff:
    Beojeff, thank you for that. As you say, AV 7000 is different. Actually, I cannot find the appropriate connector on the Beomaster 7000: is there any?
    beojeff:
    Does the same occur with the Beomaster 7000?
    For the avoidance of doubt: I am looking for a solution that enables two-way communication with my Beolink 7000 RDS
    Many thanks in advance. Kind regards, js
  • 01-04-2010 10:28 AM In reply to
    • js
    • Brussels
    • Posts 208
    • Silver Member
    tournedos:
    Too bad... Thank you anyway Tournedos.
  • 01-04-2010 12:31 PM In reply to
    While the AV7000 was only for the U.S market, it matched the 7000 family of components perfectly. Adding an AV7000 would allow you to connect a B&O "hockey puck" external sensor with a mini-rca connector. However, the AV7000 reduces the 7000 family to one-way communication and loses the 2-way communication. This was a ridiculously stupid oversight by B&O, in my opinion.
