Please forgive the basic artwork below but thought it might help show my question a bit better.....
I'm looking to replace my BV3 with a BV7. The shape of our lounge really only gives me one place for the TV in one of the alcoves next to the fireplace. Said alcove will fit a BV7-32 with BL7.1
I would prefer to buy a BV7-40 but the BL7.2 to go with this is too big for the gap and would probably hit the walls. Has anyone seen the BV7-40 with a BL7.1 below it, does it look silly? If you can point me to any pictures, that would be useful.
The other thought I have is that rather than the BL7.2 I get a couple of BL3's and stick them on the walls in the alcoves. Has anyone got a BV7 they are running this way ie. Just two side speakers and is the sound OK or would I need to get the 7.4 for a centre channel? Does it matter that one speaker will be close to the TV while the other isn't?
Any advice is welcome!
Thanks,
Chris.
* BL3 * * BL3 *
* ----BV7---- ***************************** *
* S *
* O *
* F *
* A *
* ---------- SOFA --------------------------- *
