Latest post 01-01-2010 4:34 PM by Dillen. 5 replies.
Page 1 of 1 (6 items)
  • 12-29-2009 12:40 PM
    • scuba
    • Not Ranked
    • Joined on 12-28-2008
    • Posts 48
    Counter standing still on Beocord 1200
    Hi i have a Beocord 1200 R2R that plays perfectly but the counter doesent work, is this hard to repair?
    Jon
  • 12-29-2009 2:22 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Counter standing still on Beocord 1200
    Could be that it just needs a firm push on the reset knob.
    It's quite normal to see that the counter locks in some way if not reset correctly, sometimes also
    with a ticking sound as the reels rotate.
    Alternatively, check the counter belt. Easily done by simply pulling off the aluminum cover.
    I can supply new belts if you need but check the counter reset first.
  • 12-29-2009 5:37 PM In reply to
    • scuba
    • Not Ranked
    • Posts 48
    OK,thank you Martin,is the counter belt about 1 mm wide and 34 cm long? a belt like this fell out off the R2R when i lifted it out off the box it was shipped in.
    Jon
  • 12-30-2009 3:53 AM In reply to
    • Dillen
    • Posts 5,008
    Surely something to do with this problem even if not quite the correct size.
    If it is the original belt, it has deformed and/or stretched (and probably broken by now), that's very normal.
    - Or something that someone tested in there - and it worked until it came off in transport.
    You could try mounting it again if not broken.
  • 01-01-2010 10:25 AM In reply to
    • scuba
    • Not Ranked
    • Posts 48
    Yes its probaly the missing belt that causes the problem then,the belt that fell out had snaped off,so i have to get a new one.
    Jon
  • 01-01-2010 4:34 PM In reply to
    • Dillen
    • Posts 5,008
    If one of the belts snapped, the others are probably marginal as well.
    A belt set is available for the Beocord 1200 (and also one for the very similar Beocord 1600).
    You have a PM !
