Could be that it just needs a firm push on the reset knob.
It's quite normal to see that the counter locks in some way if not reset correctly, sometimes also
with a ticking sound as the reels rotate.
Alternatively, check the counter belt. Easily done by simply pulling off the aluminum cover.
I can supply new belts if you need but check the counter reset first.
