or maybe better is Light Manager Pro for 179 euros
Transform
your remote control into a Home-Automation Commander! Why only control
the TV or DVD-Player if so much more is possible. With the Light
Manager you can additionally switch on/off your lighting.
- Dim the light
- Shut the beamer screen off
- Control electrical blinds
- Control up to 256 wireless actuators
All this can be done by your remote control, without any additional cables. A luxury, which you don't want to miss anymore.
With
the Light-Manager Pro it is possible to access even complex lighting
scenes just by pressing a button on your remote control. You cannot
only select which lights are on and off you can also define the
brightness level of each light, if appropriate actuators are used. The
Light-Manager Pro supports the InterTechno product line of radio bus
actuators as well as the FS20 line. For this purpose it contains two
transmitter modules, one for 433.92 MHz and one for 868.35 MHz. The
antennas were designed to lie inside the case completely which was
necessary to create an attractive device appearance. The Light-Manager
Pro fits nicely into your living room interior and can be placed on a
side board for example. Two LEDs at the front of the case always inform
of the current state. To assure that the LEDs are not disturbing in low
light they are automatically dimmed down so that they only glow in the
dark. It is possible to use any universal remote control with
learning capacity in conjunction with the Light-Manager Pro. To make
this possible the Light-Manager contains an infrared transmitter module
which is used to teach the remote control. The configuration of the
manager is done at the PC. Just attach it via USB bus, start the
configuration software and create your lighting scenes comfortably by
“drag and drop”. When configuration is done disconnect it from the PC
and set it up in the living room or wherever you want to use it. For
this purpose a power adapter is part of the package. It doesn't
matter if you just control a single light with one button of your
remote control or if you want to trigger a lighting scene containing a
number of lights and other electric devices. Furthermore you can mix
InterTechno as well as FS20 radio bus actuators without any limitation
even within the same scene. So it is be possible to use inexpensive
InterTechno switch actuators together with sophisticated dim actuators
of the FS20 line. The special thing about FS20 dimmers is that they
allow access to a certain level of percentage in brightness. So it
would be possible to create scenes for your living room like:
- Scene 1: Full brightness
- Scene 2: All lights on 75% (e.g. for reading)
- Scene 3: All lights on 30% (e.g. for watching movies)
- Scene 4: All lights off
During
configuration all commands can be executed in real time. This means
that while you are moving the brightness slider in Lightman Studio, all
the lights will go to that level simultaneously.
