At this point I reassembled everything and got the BL back on the charger. Fingers crossed... Hey! It works! It looks great! HOORAY!...
...wait a minute! What was THAT! It came back to life in sleep mode... OK, back to sleep, wait... ON AGAIN!!!
Quick perusal thru the manual and I found the exact symptoms in the third entry of Section 2-7... The unit switches back on (6) seconds after having been switched off (when not in charger). Well, I'll be, it is exactly (6) seconds again and again! Sadly the manual has the classic "Module pack X" replacement instructions, nothing more.
Has anyone experienced this fault? There must be a solution beyond replacing the entire module(s).
Thanks in advance for any thoughts, experiences, ideas, etc... the BL is SO close to NOT being a paper weight!
