Yes they can be reversed and I considerd them also the polished aluminium part pointing outwards, but somehow this looked and felt better. The main reasons for this are:
- the stereo image is broader this way
- BV 10 has a very elegant frame and the fabric side of BL 5000 is quite clumsy. So the two products kind of "speak" with each other better this way.
My favorite loudspeakers for this tv are BL 6000's. Especially I like the setup with blue frets. But because I already had these speakers in the bedroom, I tried them first. In the living room I have BL 6000's as rear speakers and I just ordered a pair of BL 3's to replace them. So I might try also these more slim speakers in front but first I have them as the rear ones.
The lack of display was a big disappointment for me because the tv is in the bedroom and I was used to the information from the main room.
The square corners of BL 5000 aren't actually white but brushed aluminium. In my photos they look quite white.
I noticed one thing that is'n designed so well in BV 10. That is the cover for the cords in the back. It cannot be used when installing the tv to the wall because every time you move the tv the cords tear the lid open. That is because the cords are fixed under the aluminium cable cover on the wall and cannot move. Of course the lid isn't needed when installing the tv on the wall so I stored it away and hope it will stay in good shape for the possible future use. (The cable cover on the wall is at the hinge side so the installation should be ok in that sense.)
