1st March February 2012
Latest post 12-31-2009 9:31 AM by ouverture. 16 replies.
12-24-2009 4:17 AM
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
Hi Beoworld members,
I need some help with a DVD controller type 4020 I just bought.
The cables from the adapter and the controller connected to the scart cable unfortenately has been snapped off.
Both cables have 4 wires, brown, yellow, green and blue.
Anybody here who has a schematic diagram or how to reconnect, and do I need special attention on the type of scart cable which I have to buy?
I have a technical background so if anyone can provide me the information it would be much appreciated.
Also, are there any limitations on the use of this type 4020 regarding to DVD players, because it has no SW version (NA).
Thank you very much and enjoy your Christmas holidays!
Leslie
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Leslie
- Netherlands
- Posts 2,201
Re: DVD controller wiring
Really, nobody here who can help me with my question?
Peter
- Joined on 02-12-2007
- Posts 9,572
Tricky! There is not a service manual for this! I do have a DVD controller but without pulling it apart, not sure how I can help!
Leslie
- Netherlands
- Posts 2,201
Thanks Peter!
No service manual I couldn't find either. Silly question but do you have a beeper or a multi meter?
If not then don't bother. Your help in first place is appreciated. Now, let's wait till some technical guys on this forum can help me.
I asked one already but he's not responding[:'(]
ouverture
- Joined on 04-20-2007
- London
- Posts 282
the BeoVision 1 was introduced in 2000 with the Beo1 remote which was discontinued in Q4 2002 to be replaced with the Beo4, it was at this time that you could buy three types of DVD Controller as an optional extra with the BeoVision 1, depending on the region
4020 (EU) 4021 (GB) 4022 (AUS)
the supported DVD players at the time were :
Onkyo DV-S525 02 Panasonic DMR-E50 06 Panasonic DMR-E53/DMR-E55 07 Panasonic DVD-A360 01 Panasonic DMR-EH54D 16 Philips DVD950 00 Philips DVDR70/DVDR75 03 Philips DVDR80 04 Philips VR200 09 Philips HDRW720 13 Pioneer DVDR-3100 05 Pioneer DVR-530H/DVR-630H 15 Sony RDR-GX3/RDR-GX7 08 Sony RDR-HX1010 17 Sony RDR-GX210 18/19
Leslie
- Netherlands
- Posts 2,201
Thank you Ouverture for answering my last question!
ouverture
- London
- Posts 282
and also some more info here
http://forum.beoworld.org/forums/t/13793.aspx
Leslie
- Netherlands
- Posts 2,201
Thanks a million!
But now the key question where nobody can give me the answer.
Here are some pictures, maybe this can help?
Just need to know which colors (4 pole mini din & power plug) are connected to the scart.
ouverture
- London
- Posts 282
on my DVD Controller model 4047 the wiring goes like this :
PSU Jack Wire Brown to Scart Pin 14
PSU Jack Wire Blue back to Blue wire on the DVD controller
DVD Controller Wire Brown to Scart Pin 14
DVD Controller Wire Yellow to Scart Pin 8
DVD Controller Wire Green back to Turqoise colour wire within the scart lead
I am pretty sure B&O would have wired up the 402x and the 404x models the same way, but good luck anyway :-)
Peter
Leslie
- Netherlands
- Posts 2,201
Hi Peter,
So, wire turqoise color is directly connected to the green wire of the controller?
But the turquise colored wire should be connected at one point of the scart at the other (TV) end. Am I correct? Can you measure that for me if that's the case?
Thank you so much for your help so far.
Leslie
ouverture
- London
- Posts 282
yes, the turquoise colour inside the scart lead goes to the green wire of the DVD Controller
Leslie
- Netherlands
- Posts 2,201
Thanks, but I don't have an original B&O scart cable.
You think that all scart cable have the same standardized color coding?
ouverture
- London
- Posts 282
I'm getting a tiny wattage on scart pin 8 at the TV end Leslie
so green wire on the DVD controller to TV Scart pin 8 should work I hope
Leslie
- Netherlands
- Posts 2,201
Peter, what do you mean by "tiny wattage"?
ouverture
- London
- Posts 282
my multimeter is very old and not very sensitive, and pin 8 was the only signal that blipped on the screen out of the possible 20 pins that I tested for you Leslie :-)
what DVD player are you thinking of getting, I bought two B&O DVD 1's when they first came out in 2001, one for my Avant and another for the MX7000, sadly both of them kept failing during the first 12 months, so the dealer refunded my money and gave me a DVD controller as a goodwill gesture, I then went out and bought a Panasonic DVD-A360, really superb quality and better all round than the B&O ( which was really a re-badged Philips )
Leslie
- Netherlands
- Posts 2,201
Thanks Peter, you're very helpfull.
Not sure which type I want to buy. Have to make sure what type will work on "my" controller! The one you mentioned is not available here in the Netherlands!
Hope you enjoy your Old Years Eve. Lots of noise over here at the moment (fire crackers etc.) Thanks man...
Leslie
ouverture
- London
- Posts 282
I don't think any of the DVD players are now available to buy new, you need to get a really good second user Panasonic if you can, ideally one that has been professionally serviced and is now up for sale - check your local Panasonic TV dealers first !
Page 1 of 1 (17 items)
