Latest post 04-10-2010 6:14 PM by Peter. 4 replies.
Page 1 of 1 (5 items)
  • 12-22-2009 2:27 AM
    • pagir
    • Not Ranked
    • Joined on 12-22-2009
    • Posts 8
    beogram 2400 problem
    Hello,
    I have a problem with my beogram 2400: when I press start sometimes it does not run. I must press, run and 33 to make it work. A small indicator (like a red circle) is also illuminated on the control panel (what does it meens ?).
    Help please ! Do I need to change the belt, or is it something else.
    Best regards from France, under the snow today.
    Pascal
  • 04-10-2010 4:41 PM In reply to
    • Vox_T
    • Not Ranked
    • Joined on 04-10-2010
    • Posts 14
    Re: beogram 2400 problem
    Hmm, I don't have a "start" button on my 2400. I have a "turn" button. But yes, if you are playing a 33rpm record then you should be pressing the "33" part of the button.
  • 04-10-2010 5:56 PM In reply to
    Different 2400s I think. The first one is the later model with the sloping front. I doubt it is the belt but more likely a corroded contact. Keep pressing it and see if repeated use improves it - or it will need dismantling and cleaning. The light shows the speed selected.
    The second 2400 is the pretty earlier square one with the rectangular control button - very nice! I'd love a good quality picture!
  • 04-10-2010 6:02 PM In reply to
    • Vox_T
    • Not Ranked
    • Posts 14
    Here is a picture of mine...
  • 04-10-2010 6:14 PM In reply to
    Very nice deck - I am looking for a picture for Beocentral - I edit out the background - this is one of my old decks before editing - actually fairly similar to the 2402. I need a pale background and all the deck - you will get the credit on the site!
