Latest post 12-21-2009 5:36 PM by Toubro. 3 replies.
Page 1 of 1 (4 items)
  • 12-21-2009 3:55 AM
    • Toubro
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 263
    Beovision 10 and text-tv subtitles problem
    My neighbours just received their BV10, and they use the text-tv feature to get subtitles on the danish channels a lot.
    The problem is, that on the BV10, the upper bar stays on the screen for as long as you're in text-tv mode, which is rather annoying. Their old TV did not do this.
    It seems to me that this is a BV10 problem, as the TV channel removes it's info, such as channel, date, time etc, and what's left looks like a special menu, where you can choose some different options, such as text size.
    Is there any way to turn this bar off??
  • 12-21-2009 5:18 AM In reply to
    Re: Beovision 10 and text-tv subtitles problem
    I remember this is a problem with my BV-6 too. To solve store the subtitle page to one of the memory's.
  • 12-21-2009 8:42 AM In reply to
    • tv800
    • Not Ranked
    • Joined on 09-15-2008
    • Posts 16
    Hello Toubro
    My father gor the same problem using this feature on his new BV7. The problem in his case, was, that he was using a setopbox for receiving danish channels, f.x. DR1. If you are using a setopbox, you can not use the "text" button on the remote. Is seems, that it activates the textpages, but it is not activate "the right way" .... he have to activate the textpages via the setopbox on the red function-button on the BEO4. The "text" button is only co-operation with the source activatet on the "TV" button.
    Maybe this is the same on the BV10 ?
  • 12-21-2009 5:36 PM In reply to
    • Toubro
    • Posts 263
    Zwets:
    I read the manual, and it seems this should be stored as MEMO9, so what your saying sounds right. The problem is just that I can't do this as the possibility is greyed out in the menuConfused
    tv800:
    Hello Toubro
    Thanks for your suggestion, but there's no set top box, and the red buttons activates some radio feature.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
