Hi all
Can anyone tell me what I need to capture the signals from my third party remotes, in order to create an XML file to upload to the Beo5? On the help pages Keith states:
"...if you wish to
produce your own templates for a product not currently available from B&O
or this site then you will need a means of capturing and decoding this IR
signal. There are many cheap solutions available on the web, but if you happen
to own a Lintronic converter box, then you can use that."
I don't have a Lintronic box, so what do I need to buy? What is it called? Google is not proving helpful in this instance! I have a Macintosh computer, if that is relevant.
Thanks in anticipation
Stuart
