Has anyone got any ideas why I can't set my V.OPT on my Beosystem 3 to 2? Having tried it both with the ML plug in and out, it defaults to 1 each time - this means I can't play my Overture in the same room (but works everywhere else). Has anyone else seen the same issue?
No-one?
It's driving me crazy!
Is your Overture connected to the Beosystem III by Masterlink or is it stand alone?
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
Hi
I assume that you have the BeoSystem3 connected to BeoVision4 plasma screen? If so when you option programme the BeoSystem3 does the red led blink to confirm that the command has been accepted?
Have you tried looking in the customer service menu to see what option has been stored?
Opman
frog: Hi, Has anyone got any ideas why I can't set my V.OPT on my Beosystem 3 to 2? Having tried it both with the ML plug in and out, it defaults to 1 each time - this means I can't play my Overture in the same room (but works everywhere else). Has anyone else seen the same issue?
The system is in stand-by when you program it?
In reply to your questions:
1. Yes, it is in standby when setting the option - it's the only way to do it I believe.
2. The IR receiver doesn't have the connection for the LED (I use the 3.5mm jack) but it is working well as I can control the system with the remote otherwise.
3. It is in the CS menu that I check that the Beosystem 3 is still in V.Opt.1
4. The overture is connected via ML.
Regards
Use the original IR-eye!
How does that help? The only difference between the cabling is for the lights on the eye (I'm using an original eye, but without all pins connected).
I also don't have the cabling....
Problem solved with a full system reset to factory settings. Took ages to reset everything afterward
